It is currently Sat Nov 23, 2024 1:10 am
Landsharks 76er Refresh and Build
Re: Landsharks 76er Refresh and Build
actually the glass and the rubber are all good.. Matter of fact i ran a screw driver under the edges and its very elastic still.. would love to save what i can so i can afford other parts down the road.
so do i pry the outside out first or the inside? sounds like the outside from what i can see as the black sealer is under the outside lip.
Should i just pry it up and peel it away? i was afraid of ripping the rubber so stopped. Would like to get it out before the move to save on time.. still have a few more hours of tear down and covering to do.
Wed May 09, 2012 8:53 am |
You need to keep everything well lubed with soapy water. Then from the inside, one corner (I generally prefer to work from the top) you can pry and work the rubber from the inside to the outside. Work equally down the side and across the top (easiest if you remove the rear view mirror first) until you have the whole side and top out. At that point it will be very easy to lift the whole thing, glass and gasket out of the hole at once.
Just remember - it is glass, do not pry against it directly - pry against the gasket, and do not force it. Take you time, work gently and slowly, you will be just fine. Once you have done one or two you will have a pretty good feel for the rest and they will go much faster.
Wed May 09, 2012 9:46 am |
Wed May 09, 2012 9:50 am |
Based on the video from WH looks like you are simply trying to push the rubber lip from the inside of the cab to the outside. That's the opposite they did with the rope in the video.
Wed May 09, 2012 10:00 am |
Wed May 09, 2012 1:05 pm |
Good news! I got the rubber out intact and in one piece! Bad news I broke the windshield.. oh well it happens.. i will just add it to my parts list.. Just have a few things left on the dash panel to pull off and I think its pretty much ready to roll..
Thu May 10, 2012 12:34 am |
Thu May 10, 2012 4:02 pm |
wazzuuuuuupp ! ! ! ! !
I am really excited for you..... areal life frame off in the works !
You gonna stick with original color or change it up ?
Thu May 10, 2012 9:08 pm |
Going back to stock color of Glenn green which seems to be some debate on the exact color itself but I have a good idea. Don't see many green ones so a bit of a risk but will be fun.
Thu May 10, 2012 10:28 pm |
Ought to be real interesting to see what Glen Green looks like when put on the outside. Hope the painter can get it matched but then again if you have it blasted inside and out there won't be a problem. When my dad had to have his (my current) Bronco repaired, after flopping it on it's side on an icy road, the Ford dealer could not get the paint to match even even with the paint code. It took them a couple tries to get it, the blue came out lighter than what was on the Bronco originally. You would think the dealer could get the paint right but not always the case.
Fri May 11, 2012 5:00 am |
Since you are painting the whole truck, an exact match is not as important as if you were just painting one or two panels, just make sure you are happy with the color. Even with a scanner, or paint code you still may not pull an "exact" match. That depends on the brand of paint and how well that brand matched your color. The shop I worked at has used a few different paint brands in the last 10 years and each had its good matches and its bad matches. My old shop and another shop in town just changed to a water based system, and both shops say this new brand (don't know the name) impressed them with the color matches. Normally, if a color doesn't match perfect, we'd blend the adjacent panels so the color difference couldn't be seen. If you can't or don't want to blend the other panels, that is when you can see the difference. A good painter should be able to custom tint a paint and come very close. BTW, my truck was rolled before I bought it, and they used some j/y parts to fix it. The tail gate has the "Sport" chrome trim, and part of the chrome just broke and fell off, under my tire carrier. Under the chrome was the original (probably) paint, a very cool green. The paint looks pretty "new" because its been protected by the chrome molding. I thought of you when I saw it. If this is the color you end up with, I really like it. If you have problems matching, I could run my truck to my old shop and have them scan that part of my truck and get you a color code. Chad
Fri May 11, 2012 7:46 am |
As they are going to blast the whole truck and iam going to repaint inside and out Iam trying to find the original color #'s to try and match (Color Code U). The only part of the truck iam not painting is the inside of the glove box door... something has to stay original ;) I think the inside of the glovebox would be the most representative of the original color since its probably not fadded and hasn't really been scratched too much... I think it will look nice... Crappy copy but here are the paint chips from my year...
Fri May 11, 2012 8:49 am |
I think one of the Broncos in Wild Horses ads is Glen Green: http://www.wildhorses4x4.com/category/Early_Ford_Bronco
Fri May 11, 2012 10:02 am |
maybe so hard to tell, you saw how the color was different from one piece to the next.. i think it will be a nice stand out since there aren't many out there that color. With the white top and maybe tint the windows a little out back it will be a nice change.
I just ordered the marti report for it.. so interested to see what it comes back with. Also picking up the actual page for the 76 truck paint chip book.. so i can get the exact color.
Fri May 11, 2012 10:57 am |
From your chips & glovebox I'd say my tailgate is NOT Glen Green. I don't know what year its from so who knows. Oh yeah, I'm slightly colorblind too.
Good Luck
Fri May 11, 2012 1:29 pm |
Sun May 13, 2012 12:16 pm |
Buy a block that matches the heads!
Sun May 13, 2012 1:47 pm |
Sun May 13, 2012 2:28 pm |
Ya so far opinion is get the e7's refreshed and run those. And your right I would rather put a 351 in the full size ;)
Sun May 13, 2012 2:34 pm |
17Nov78 is the casting date on the block. Heads look pretty normal. Some carbon on the pistons is normal. They look a little oilier than usual around the rings.
Sun May 13, 2012 10:23 pm |
Mon May 14, 2012 6:43 am |
Well visited the blaster on Thursday and they started blasting. Should be done tomorrow. So far no surprises. A little hole in the drivers side rocker. Will have lots of pics this week but here's a couple before they were done
Mon May 21, 2012 10:39 pm |
Tue May 29, 2012 2:53 pm |
Got some patchwork to do, but it sure is nice to be able to see it all and know that you repaired everything, then sealed it so in 40 years it'll still be solid!
Tue May 29, 2012 3:02 pm |
How nice to have the blasting done savining hundreds of hours of sanding and stripping. Can't think of a better present than having the body be that solid and rust-free.
Tue May 29, 2012 4:31 pm |
I'm jealous. That thing is clean! I can't wait to get mine to that spot.
Tue May 29, 2012 5:33 pm |
WOW ! That is a great survivor worthy of what you are doing. Can't wait to see it progress into a real jewel. PS..........keep the cost down so the sale price isn't out of my reach.
Tue May 29, 2012 10:25 pm |
thanks guys, ya was nice to have it back from the blaster.. not too many surprises... now onto body patching and building up the engine ;)
Tue May 29, 2012 10:42 pm |
got my marti report... i figured i had the stripe delete so thats swell. i dont like the stripes anyway ;)
Wed May 30, 2012 1:08 pm |
airbur
That is sweet!!
Wed May 30, 2012 1:10 pm |
Users browsing this forum: No registered users and 53 guests |
