It is currently Mon Nov 25, 2024 8:23 pm
[ 4 posts ] |
Leaf spring bushings
Don't really have a question about them. Stopped off at Predator 4WD today to see about getting new bushings installed in the Super Duty springs. $621.00 for an estimated 6 hours of work. When did shop labor rates go to 100/hour?
Fri Jun 01, 2012 8:18 pm |
Colorado75bronc
Labor sounds right, about 1 1/2 hours per spring but he used to be 85 an hour he's crazy if he went to 100
Sat Jun 02, 2012 3:17 pm |
cracker
Joined: Mon Oct 04, 2010 9:19 am Posts: 113 Location: pueblo
Re: Leaf spring bushings
That is Predator for you. They are on the high side... For the money, you can buy a press from Harbor Freight and do them yourself and still save alot of money.
_________________ 1-1966 Bronco 1-1967 Bronco 1-1969 Bronco 2-1973 Broncos And a couple even run.....
Fri Jun 08, 2012 3:39 pm |
Shawns Fords
We were at 138.00 hr in Steamboat. It has been around that for a long time at most shops. And the techs are still getting paid the same for 20 years.
A friend of mine worked at predator for a while, he couldn't make a living on the income and he does phenomenal work, ended up moving back to Florida.
Sun Jun 10, 2012 9:45 am |
[ 4 posts ] |
Users browsing this forum: No registered users and 69 guests |
