Register •
FAQ
• Login
It is currently Sun Nov 24, 2024 11:21 pm
[ 4 posts ] |
cooling issues while pulling with 400. not eb related sorry
Palmer72bronco
while pulling my new toy this weekend i got a little hot on big pulls. around 210-240 depending on the length of the pull. when at idle its fine, around town, no problems. i have a 190 thermostat, fan shroud, 7 blade clutch fan. stock water pump, has the big radiator that is hard to find from ford. even didnt heat up coming back down. trying to keep this more managable. any ideas comments concerns appreciated. bronco does same thing on the highway but is fine crawling and around town. i have a/c on the pickup so i know the condenser is going to take some air. thanks guys
Wed Jun 06, 2012 12:52 pm |
Re: cooling issues while pulling with 400. not eb related so
That's where your going to see the highest temps. Is the clutch on the fan working properly? It should be tight when it's hot. I've had a few of those and replaced them with a good flex fan but when they work they work pretty well.
Fri Jun 08, 2012 7:18 pm |
Palmer72bronco
how would i check if the clutch on the fan is working properly
Fri Jun 08, 2012 10:51 pm |
The clutch should spin by hand fairly easily when cold and when it is hot it should hardly spin by hand.
Sun Jun 10, 2012 5:56 am |
[ 4 posts ] |
