It is currently Fri Nov 22, 2024 2:28 pm
[ 7 posts ] |
Badlands
Rocker trim
Looking for original rocker trim and clips. Doesn't appear to be reproduced or sold elsewhere.
Wed Jun 13, 2012 9:17 am |
Re: Rocker trim
Ah, dammit. There was a set just up on Craigslist maybe a week ago in the Denver area for 20 bucks or so. I was gonna pick them up just because. They're gone now. I'll keep an eye out though.
Might PM Dalli and see if he has any at his COS yard.
Wed Jun 13, 2012 10:22 am |
Badlands
Re: Rocker trim
Thanks Frank. That sounds like an incredible deal and much less than what I anticipated. Just to clarify, this set was for the outside of the rocker under the door with the clips? Like on this Bronco I have seen around. Funny there no reproductions out there.
Wed Jun 13, 2012 2:13 pm |
Re: Rocker trim
That trim looks a lot like the early mustang rocker trim. I may have some of it laying around if it will work. I am sure you will have to cut it to fit. I will look when I get home. It would be from a 66 stang.
Wed Jun 13, 2012 2:47 pm |
Re: Rocker trim
Wed Jun 13, 2012 3:04 pm |
Badlands
Re: Rocker trim
Wed Jun 13, 2012 4:22 pm |
Re: Rocker trim
I found one side - might be long enough for both, I dont know. I will bring it to the breakfast. just in case, here is a link for one of the mustang vendors who sells the trim and clips. http://www.cjponyparts.com/rocker-panel ... 6/p/RPM1L/
Thu Jun 14, 2012 6:04 am |
[ 7 posts ] |
Users browsing this forum: No registered users and 28 guests |
