It is currently Mon Nov 25, 2024 8:15 pm
[ 7 posts ] |
Gear banger
Anyone ever used WH's gear banger? I'm running into issues installing my twin stick due to the long throws of my NP435. Reviews?
Wed Jun 06, 2012 11:20 pm |
Re: Gear banger
Cory also has one.
Thu Jun 07, 2012 6:20 am |
sbolt19
Re: Gear banger
I've talked to Cory about it a couple of times and he seems to like his. If I remember right, he said it shifts smoother.
Thu Jun 07, 2012 11:06 am |
Gear banger
Everything I have ever heard about them has always come back two .
Thu Jun 07, 2012 11:25 am |
Re: Gear banger
I made my own and never liked it. But that could be blamed on the engineer or possibly my tranny. I couldn't find my gears, felt way sloppy. I ended up buying a new shifter & going back. Paid more for the shifter than I paid for my whole tranny.
I'll give you my cut off shifter stub (which also could be the problem, it shows some signs of wear), so if you don't like it you haven't cut yours up.
edit: I'll give you the whole thing I made and you could try it and see if it works, then after you realize it sucks, you can try a WH and see how the pros do it.
Chad
Thu Jun 07, 2012 12:22 pm |
cracker
Joined: Mon Oct 04, 2010 9:19 am Posts: 113 Location: pueblo
Re: Gear banger
I have one that I have yet to install. Bought it when they first came out. The only problem for me that I see is hitting my center console... One of these days I might get it in...
_________________ 1-1966 Bronco 1-1967 Bronco 1-1969 Bronco 2-1973 Broncos And a couple even run.....
Fri Jun 08, 2012 3:37 pm |
trei75bronco
Joined: Wed Jan 26, 2011 10:55 pm Posts: 837 Images: 0
Re: Gear banger
They are worth it. Love mine. I was going to make one but its cheaper to buy
Mon Jun 18, 2012 8:28 pm |
[ 7 posts ] |
