www.ColoradoClassicBroncos.com - View topic - 302 won't fire
It is currently Mon Nov 25, 2024 12:42 am
Reply to topic  [ 15 posts ]
 302 won't fire
Post 302 won't fire
Drews bronco was backfiring like crazy, so I put my hand on top of the dist to adjust the timing, and got zapped. The plug wires were cut-cracked. So off to napa and we get new plugs, wires, cap and rotor.
Put it all on, and guess what? No zoom, zoom.
Any one have any great ideas?
Anyone feel like coming over to play broncos and help out? Plenty of cold ones as payment.
Sat Jun 16, 2012 5:41 pm
Post Re: 302 won't fire
Try a coil too.
Sat Jun 16, 2012 6:05 pm
Greg,
The ignition module was relatively new, as were the cap and rotor, and plugs.
I would guess coil or firing order.
Sat Jun 16, 2012 6:09 pm
We did that, put an extra one we had lying about on.... Shocked the crap out of drew too...
Sat Jun 16, 2012 6:11 pm
Keep at it. The shocking means it's working - take turns holding it. popcorn
Sat Jun 16, 2012 6:18 pm
Sat Jun 16, 2012 8:15 pm
We got it!
Finally pulled the number 1 plug, found the top and pulled the cap, found number 1 on the rotor and reset the wires accordingly. Turned the key and fired her right up. Set the timing a at 10 degrees advanced, might be a bit to much but she is running better than she has in months.
Oh, and we fixed the signature "Rox Crusher" squeal too!
Sat Jun 16, 2012 8:47 pm
Whew, I was thinking the ol block of wood and a hammer were coming out while I began reading this.
Wed Jun 20, 2012 10:19 pm
Nope, just pulled the old wrecked motor over, set the hammer and block on the fender, scared the engine into fixing itself
Wed Jun 20, 2012 10:24 pm
Are you sure Drew needs a better running motor?
Thu Jun 21, 2012 8:18 am
Yeah, he does. He is leaving for work at 430am, mon-fri. The squealing alt and backfiring that sounded like a 30-06 going off 15 times in the driveway was disturbing the neighbors, but more importantly, it was pissing off the queen of the household.
Yes, he needed a better running motor.
We all needed him to have a better running motor
Thu Jun 21, 2012 8:24 am
Yeah, I see your point!
Rubber side down buddy!
Thu Jun 21, 2012 8:29 am
Yeah - I think he has learned that lesson pretty well - the expense of his heavy right foot has cost him pretty dearly since he earned his license in late April... starter, rear end, fluids, seals etc... not to mention fuel!
On the bright side - he is getting 12-14mpg since the tune up!
But his mother will not let him run topless this summer - and the drive home from work has been brutal so far (he gets off at 2:30p and it has been HOT!) - seems like we may be having some minor vapor lock issues. Going to try the wood clothes pin trick tonight. He is working near the Denver Zoo and we live in Highlands Ranch - cross town traffic on 100 degree days...
Thu Jun 21, 2012 8:38 am
Do you want to cut the hood?
I've put hood vents like this in my '74
I have some, but they are located in Monte Vista.
There are better functioning ones:
Thu Jun 21, 2012 8:42 am
not a bad idea, we already have a hole in it for the air cleaner and just put a scoop on it. We need to open up the hole more I am sure.
I will suggest it to him.
Thanks
Thu Jun 21, 2012 8:47 am
Users browsing this forum: No registered users and 34 guests
33,020,039 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
