It is currently Thu Nov 21, 2024 7:47 pm
Postponed- COS Bronco BBQ, Bear Creek Park, Colorado Springs
Two years ago we ran a BBQ in Colorado Springs at Bear Creek park. Aside from all of the vapor locking and lack of a pavilion, everyone seemed to have fun. So, we're looking to do it again this year!
Reservations are currently in for 25 August with a pavilion and seating for 50. More than that are welcome to attend and we'll be checking back often to see if a larger pavilion opens up. We'll have the pavilion from 5am-11pm, so no worries on fighting for our spot. Two built in grills are available for our use and until fire bans are lifted, only propane grills can be used to augment that.
Keep checking back and we'll get information posted up regarding food, events, and other details.
We're looking to try and include a morning trail run prior to the BBQ for you dirt and rock junkies.
Tue Jun 19, 2012 11:40 am |
cracker
Joined: Mon Oct 04, 2010 9:19 am Posts: 113 Location: pueblo
Re: 25 August- COS Bronco BBQ, Bear Creek Park, Colorado Spr
I will put it down on my calender and check back.... Where is Bear Creek Park?
_________________ 1-1966 Bronco 1-1967 Bronco 1-1969 Bronco 2-1973 Broncos And a couple even run.....
Tue Jun 19, 2012 11:56 am |
ClayJ
Tue Jun 19, 2012 12:45 pm |
Colorado75bronc
25 August- COS Bronco BBQ, Bear Creek Park, Colorado Springs
I'll be there!
Tue Jun 19, 2012 3:10 pm |
cwin74
Joined: Tue Apr 17, 2012 7:37 am Posts: 139 Images: 0 Location: Broomfield - Colorado
I'll attend if I can.
Wed Jun 20, 2012 7:04 am |
Putting it on the calendar.
Wed Jun 20, 2012 8:37 am |
On my calendar too.
Sat Jun 23, 2012 6:35 pm |
On my calendar
Sat Jun 23, 2012 9:10 pm |
MoneyPit
Joined: Thu Jul 28, 2011 8:39 am Posts: 69 Location: Commerce City
I put it on my calendar too.
_________________ Doug
Sun Jun 24, 2012 5:53 pm |
Moab Mike
Count me in.
Sun Jun 24, 2012 5:58 pm |
ClayJ
If the weather continues hot and dry, the built in charcoal grills might be off limits. We might need a couple gassers for g.
Mon Jul 02, 2012 3:12 pm |
Definitely keeping that in mind. I hate propane grilling but I hate packing up and moving my valuables more.
Mon Jul 02, 2012 7:21 pm |
As predicted, El Paso Parks and Rec removed all the charcoal grills from all parks earlier this week. Propane is still good to go.
Time to gauge a little interest. Looking to find out how many of you guys and gals might be interested in a mild trail run before the BBQ.
Based on travel time to local trails, we would likely have to push the start time of the BBQ an hour or so to the right, ~1:00PM or so. If we have a majority who are simply interested in grub and games, we'll keep the start time @ 12:00 and the trail runners can grab their food and join in after they get back.
Suggested trails would be: Mount Baldy for the stockers and gawkers.
Eagle Rock for the lockers and rockers.
I've added a poll to the original post. Please chime in with your interested participation.
Depending on interest from the masses, we could be looking for trail leaders for each of the runs.
Thu Jul 05, 2012 10:10 am |
Colorado75bronc
I'd be up for either as long as I've got the front regeared and locked by then, and I wouldn't mind heading up eagle rock/saran wrap as I'm pretty familiar with the trails, not as much with baldy though
Thu Jul 05, 2012 1:08 pm |
D&D72
As much as I would like to attend.... My Employer has other ideas
Wed Jul 11, 2012 10:22 am |
Colorado75bronc
Just thought id bring this back up, are we still going to do this, and I hope the guys that just started up alpineclassicbroncos will join us
Mon Aug 06, 2012 8:49 am |
cracker
I am still attending... Big circle on my calender tells me so..
Mon Aug 06, 2012 10:54 am |
Aztec77Bronco
Joined: Thu Jul 05, 2012 11:54 am Posts: 119 Images: 0 Location: Just south of Durango
I can't go, Post Pics! :(
_________________ '77 Sport, 302 HO on it's way to a resurrection! '03 Mercedes CLK 320 Cabriolet (W208 body) '13 Ford F350 Lariat Crew Cab 4wd Power Stroke
Mon Aug 06, 2012 1:32 pm |
I might come depending on what time it goes till. I'm working till 5, but may be able to cruise down following.
Mon Aug 06, 2012 9:48 pm |
ClayJ
Zack
Have you actually reserved a pavillion or are we just going to try to get their early and squat? I don't even know if you can reserve anyting in that park.
Tue Aug 07, 2012 3:47 pm |
You most certainly can reserve a pavilion. We're in pavilion #3 and have the reservation for the entire day.
Tue Aug 07, 2012 4:02 pm |
giantacairrider
Joined: Thu Oct 06, 2011 8:50 pm Posts: 45 Location: Colorado Springs, CO
I should be there.
Wed Aug 08, 2012 7:51 am |
Corey you still gonna wheel that morning? If so I might tow the Bronco down and join in.
Thu Aug 09, 2012 6:35 am |
Colorado75bronc
I may, I have get a set of 4.10's for the front to match and hack up the rear wheel tubs for the stretch
Thu Aug 09, 2012 8:41 am |
ImIn4Lo
Joined: Thu Mar 01, 2012 10:45 am Posts: 94 Images: 0 Location: Colorado Springs
Im bummed that I dont get to go... Could go the 26th. Figures. I hope you all have fun. Id soooooo run Eagle Rock with you.
Fri Aug 10, 2012 10:49 am |
So, I've updated the first post with a new thread. Please indicate, as best you can, how many people you will be bringing and if you can come.
Unfortunately for me, work has other plans for that week. However, the pavilion is still laid on for us! I'm looking for someone in the COS area that I can drop off the vittles and charcoal to. Any volunteers?
Once again, the pavilion is ours from park open to park close, so please take advantage.
Trail run poll results were (4) for Mount Baldy and (2) for Eagle Rock. If we have some volunteers who can lead those runs, that would be great.
Sun Aug 12, 2012 8:38 am |
Any idea about what time this will start? I'm game to come down, but won't be able to until after work.
Sun Aug 12, 2012 1:23 pm |
I'd intended on spending most of the day at the park. If anything, it would be nice to get out of the house and chill out in some fresh air with the Bronco. Now, it will be solely dependent upon whomever decides to show up. I'd imagine those running trails will not make it to the park until 1-ish. With volleyball courts, soccer fields, and the great outdoors there should be plenty to keep people occupied. I'd hoped to throw in a visit by some people from work, but I don't think that is going to happen now. We'll see.
Bottom line is, it's our day. Enjoy as much or as little of it as you like!
Sun Aug 12, 2012 1:55 pm |
cracker
I have run all of the trails up there, so no problem if you need a trail guide. Prefer Saran Wrap/Eagle Rock to Baldy, as they are more fun for me... What do we need to bring for the BBQ???
Mon Aug 13, 2012 10:55 am |
I've got 2 bags of Matchlight in the garage and will pick up more this week if it looks as though interest will warrant it.
I'm going to pick up somewhere around 6 boxes (72) Bubba burgers too.
So, that leaves: Condiments Drinks (non-alcoholic, it is a city park after all) Plates, forks, etc. Side dishes Chips
The usual BBQ fixins.
Mon Aug 13, 2012 4:27 pm |
Users browsing this forum: No registered users and 22 guests |
