www.ColoradoClassicBroncos.com - View topic - Door Latch Swap
It is currently Mon Nov 25, 2024 12:23 am
Reply to topic  [ 8 posts ]
 Door Latch Swap
Post Door Latch Swap
Is it possible to retrofit the paddle-type internal door handles to a 66 door? I'd want to leave the external stuff in the same place, but I'd much prefer the paddle handle to the crank style that came stock.
I don't have access to a set of paddle handles, but assuming they pull the latch the same way it should just be a matter of mounting them up and making a rod to fit, right?
I need to look inside of someone's later-model doors and my 66 doors and see if we can figure out a solution to upgrade me to the paddles.
1966 Bronco (Aug. 1965 production date), 5.0L Explorer EFI, 33x12.50 BFG AT
Tue Jul 10, 2012 12:17 am
Profile YIM WWW
Post Re: Door Latch Swap
You will have to do some cutting and maybe some welding for the hole where the later style latch goes but I'm sure its doable. The holes in the door behind the inner door panel are not the same as I recall. I have a set of 66 doors that were converted to the later style striker and latch but the guts have all been removed so I don't know exactly how they were set up. I have both styles and I prefer the early style to the paddle latches because the latter style has given me more problems.
Tue Jul 10, 2012 12:43 am
Yeah, that's what I figured. I'm not opposed to welding and cutting to get the job done, but I'd like to get a gander at a 68-77 door to see what I'm working with.
Maybe I'll head north next weekend and poke around the Bronco boneyard in Springs to see if I can piece something together.
BTW, how's my old Dana 30 running?
Tue Jul 10, 2012 12:54 am
Profile YIM WWW
Have you considered cutting out your door posts and welding in 68-77 style posts in their place? That would give you the option of reselling your current doors and would probably require less fab work.
Tue Jul 10, 2012 4:35 pm
It would be alot easier to just change the door striker than trying to change the inside of the door. But, if you want to look inside a 68-77 door, let me know you can come by and look at a set I have.
1-1966 Bronco
1-1967 Bronco
1-1969 Bronco
2-1973 Broncos
And a couple even run.....
Tue Jul 10, 2012 4:43 pm
Profile WWW
Tue Jul 10, 2012 10:05 pm
Glad to hear it's still ticking on. If I hadn't gotten the cherry deal on the D44, I would have rebuilt it's kingpins myself and used it.
Tue Jul 10, 2012 11:46 pm
Profile YIM WWW
I'm not finding the photos I thought I had of my 74 doors but I need to pull the inner panel off of my 68 to reattach the rod to the outside handle. If I get to that this weekend, I can take some good shots for you.
Wed Jul 11, 2012 9:53 pm
Users browsing this forum: No registered users and 15 guests
33,019,277 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
