www.ColoradoClassicBroncos.com - View topic - NP 435
It is currently Mon Nov 25, 2024 12:40 am
Reply to topic  [ 6 posts ]
 NP 435
Post NP 435
8km3g-3097806825@sale.craigslist.org
Does this appear to be the correct Np 435 for a bronco swap.
If so how intensive is the swap?
Thu Jul 12, 2012 4:01 pm
Post Re: NP 435
http://fortcollins.craigslist.org/pts/3097806825.html
I think this link will work
Thu Jul 12, 2012 4:05 pm
Post Re: NP 435
I never quite got to grips with what vehicles the right NP435s came out of. I think mine came from a vehicle that wasn't "on the list".
The important thing is that it is a 28 spline output shaft.
There are two bolt patterns for the t-case/tranny mount. "A" shaped and "square". Adapters are available for both, but you should do more research, I put mine in over 10 years ago, and I don't remember much of what I read then.
Mine was from a 69? F150 4x4 w/28 spline & A shaped bolt pattern. But, according to this:
http://classicbroncos.com/tech/np435-4- ... sion-guide
it shouldn't have had a 28 spline output shaft, but it did.
You'll need your 3 speed bellhousing, the FE block bellhousing won't work on a 302.
Thu Jul 12, 2012 6:01 pm
Post Re: NP 435
You also need the adapter plate & the 6 cylinder intermediate housing if I remember right. But you definitely need the square bolt pattern. Like Gunni, I did mine well over 10 years ago, but you have to get one out of a 2wd truck because the output shaft on a 4x4 is longer and would have to be swapped out. Doable, but easier if you are able to find the 2wd version.
Fri Jul 13, 2012 9:22 am
Post Re: NP 435
i have two sitting at my parents house. on out of a late 77 f250 with mated t case and one out of a 76 f250 with divorced set up if you want to come look at them or if they will work
Sat Jul 14, 2012 10:53 am
Post Re: NP 435
I just got an extra adapter and 6 cyl housing for this swap if you are interested.
66 1/2 Cab Rock Toy
68 Mall Crawler (someday)
Mon Jul 16, 2012 9:38 am
Users browsing this forum: No registered users and 35 guests
33,019,934 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
