www.ColoradoClassicBroncos.com - View topic - Dash Layout
It is currently Mon Nov 25, 2024 1:55 am
Reply to topic  [ 12 posts ]
 Dash Layout
Post Dash Layout
Going to have my BC Broncos blank dash (with glove box hole) water jet cut soon, so I've been playing around with layouts. I think this is what I've settled on:
To explain, the gray bars are where the roll cage front legs drop in front of the dash. I'm converting all electrical controls in the dashboard (headlights, wipers, washer, etc. etc. etc.) to Carling Contura V switches of appropriate design so that's why you see a lack of round holes and a bunch of rectangles.
The black is going to be water jet cut 3/16" aluminum powder coated black to make switch panels and surrounds for the AC vents, AC control (vintage Streamline 4-knob), power port and ignition button (I'm doing keyless RFID ignition I think). They'll be screwed into the dash from behind so there shouldn't be any screws visible.
The instrument cluster will be a Dakota VHX in anodized aluminum finish. All dash lights will be red. I'll probably design (and have water jetted) a custom matching bezel for the gauge cluster that hides those screws and use a NicksTrix billet steering wheel filler panel powder coated black.
Dash will be body color (right now a toss up between Blazing Copper and Jeep Rescue Green).
Whaddya think?
1966 Bronco (Aug. 1965 production date), 5.0L Explorer EFI, 33x12.50 BFG AT
Tue Jul 10, 2012 5:39 pm
Profile YIM WWW
Post Re: Dash Layout
it bothers me that there isn't a 4th ac vent... symmetry I guess icon biggin
It's going to look really sharp when you're done! Those Dakota guages are killer and with the Carling switches it's going to look like a fighter cockpit or something. Can't wait to see it finished!
Wed Jul 11, 2012 4:08 pm
Put a set of speakers at the outside edges, behind the roll cage legs. Some nice Polk Audio marine grade, like the DB501 (5") fit, but need @1/2" trimmed off the sides of the cover to fit between the glove box hole and side. Really just the glove box side needs trimming.
Joe
Sun Jul 15, 2012 9:58 am
Sun Jul 15, 2012 10:57 am
The biggest speakers I could fit in the edges would be 4". I think I'd rather just put them in the doors and use 5.25".
Anyone have the EXACT diameter of the stock gauge hole? My stock dash is kinda bent up so I don't trust the measurements.
Sun Jul 15, 2012 4:23 pm
Profile YIM WWW
And the Vintage kit I have only has three dash vent outlets. While I could do a splitter for 4, it seems silly.
Besides, I (the driver) deserve 2x more vents than the passenger. :)
Sun Jul 15, 2012 4:25 pm
Profile YIM WWW
Post Dash Layout
Exactly 6.5". Maybe .001 of a hair smaller.
Sun Jul 15, 2012 6:20 pm
Punisher - that is sweet that the speedo is 6.5". The same speaker in a 6.5" version will sound better than a 5.25" speaker - physics.
Mon Jul 16, 2012 10:15 am
Thank you sir.
Mon Jul 16, 2012 11:07 pm
Profile YIM WWW
Okay... new idea because water jetting the dashboard was sounding like a bit of a pain in the butt and I wanted something that has a bit more dimension to it than stuff mounted to steel...
The black will be 1/4" water jet cut aluminum routed around the edge to look like it was milled and then powder coated a crinkle black. Orange is the dash metal. Exposed hex-head button cap screws countersunk into the bezels. Carling switches for everything. Dakota VHX gauges. Custom-made glove box door to match.
Insets on the sides are to clear the roll bar.
Thoughts?
Fri Jul 20, 2012 1:42 pm
Profile YIM WWW
Wicked. I like that lots.
Fri Jul 20, 2012 5:29 pm
That looks sweet. Looking forward to seeing the finished product.
Sun Jul 22, 2012 8:02 am
33,022,556 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
