www.ColoradoClassicBroncos.com - View topic - WH now stocks MSD. New Atomic EFI kits ready to ship.
It is currently Sat Nov 23, 2024 2:08 am
Reply to topic  [ 17 posts ]
Post WH now stocks MSD. New Atomic EFI kits ready to ship.
We liked the new MSD Atomic EFI kit so much we became a stocking distributor. Check out the kit here.
http://www.wildhorses4x4.com/product/MS ... D_Ignition
Real simple install, see the video.
For special COLO classic deal PM full name, billing and shipping address, phone etc.
Like us on Facebook for special deals and promotions.
http://www.facebook.com/WildHorses4x4
Thu Jul 19, 2012 2:42 pm
Profile WWW
Post Re: WH now stocks MSD. New Atomic EFI kits ready to ship.
Sweet, thanks for the hookup!
Thu Jul 19, 2012 6:30 pm
This is on my Winter ToDo list so this great timing. Thanks for letting us know. Love to hear any stories or pics from your installs.
Mon Jul 23, 2012 1:13 am
Mon Jul 23, 2012 1:54 pm
These aren't mass air flow. Probably only good for a mildly built 302/351 correct?
Mon Jul 23, 2012 2:28 pm
Mon Jul 23, 2012 4:48 pm
Mon Jul 23, 2012 4:49 pm
Profile WWW
If there's lots of adjustability (user friendly adjustability) built into a speed density system you should be able to use it on almost anything within the limits of its fuel delivery capability. The problem with the old Ford SD systems is it wasn't really user friendly adjustable.
Mon Jul 23, 2012 5:38 pm
I really like the return less fuel line so I can keep my current WH 23 gallon non efi tank. Add in the quick install, new fuel pump, brand name, use standard air cleaner, etc. all makes this a sweet package. I am really close to PM'ing.
Tue Jul 24, 2012 12:48 am
Unless things have changed the return less system is not gonna happen. Booger looked into this system when it first hit the market. He found that only under perfect conditions between like 70-86deg and not more than 1000' elevation and no more than like 50 crank horsepower was it a return less system. I do like the system and will be watching the install.
Tue Jul 24, 2012 6:33 am
Tue Jul 24, 2012 6:41 am
My friend and I just installed this in my rig. Actually the full MSD ignition/ Atomic EFI with return. My engine is a 302 stroked to 347CI and the Atomic keeps up just fine. Super easy to program, took away the majority of the gas smell and made the idle much smoother. First thing I did was drive from Chatty to Echo Lake to see how the EFI handled the elevation change, which was an issue with the carb. I could not tell a difference in performance at all across the 5000' elevation change and it fired right up at the top. I have not had it long enough to talk about improved gas mileage but I will update when I have.
Best part is with the lo-pro air cleaner you can still keep the original hood with no mod
Tue Jul 24, 2012 9:16 pm
Goodness! that shore looks purdy!! (seriously, looks nice)
Thu Jul 26, 2012 7:41 am
I just want to make sure I understand the trade off of this kit vs a self rolled conversion.
This kit is in excess of $2k, but it bolts on fast and is designed to be easy to install and customize.
Self rolled requires u-pull-it parts, harnesses, programming, lots of learning, and lots of time, but winds up substantially cheaper.
Correct?
Mon Jul 30, 2012 1:43 pm
Tue Aug 07, 2012 7:27 pm
Tue Aug 07, 2012 8:07 pm
Profile YIM
Glad to hear that steve. One other thing we can try is to reset the base idle speed again. But I think the tight torque convertor is whats causing the issue. When you drop it in gear and you get a few hundred rpm drop, the idle air controller is trying to make it idle at 850rpm yet the torque converter pulls it lower. So it "hunts" to find that rpm again.
Tue Aug 07, 2012 8:29 pm
32,964,474 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
