It is currently Tue Nov 26, 2024 5:55 pm
Landsharks 76er Refresh and Build
Re: Landsharks 76er Refresh and Build
The filter fitting unscrews and the explorer parts can swap right over.
Tue Jul 17, 2012 10:53 am |
Tue Jul 17, 2012 10:57 am |
Hard to say. Ford put them on the explorers for a reason though.
Tue Jul 17, 2012 11:08 am |
so i can unscrew the oil stud that is in the block and install the cooler?
Tue Jul 17, 2012 11:11 am |
Yes. As long as you have the explorer hollow bolt and big and small o-rings. It's a tight fit between the cooler and the cross member. You might have to remove the drip rail from the cooler. You can also clock the cooler up a little by trimming the locating tab.
Tue Jul 17, 2012 12:49 pm |
Tue Jul 17, 2012 1:57 pm |
Tue Jul 17, 2012 3:56 pm |
Badlands
Looking good Chris. You have gotten a lot done! My fan sits inside my shroud a little too far and doesn't draw air properly. I'll have to see what you fab up and copy how you do it but with the right depth for me.
Tue Jul 17, 2012 4:38 pm |
Thanks. I will probably make the shroud that's listed on the Ccb serp write up. Just need to go get the aluminum. Got the wiper motor and mechanics installed. Also picked up my new to me wheels and tires.
Tue Jul 17, 2012 9:07 pm |
Got the tail lights, sidemarker lights and all the rear wiring in.. so thats done.. i hope. I guess i need to order up some stuff from one of the vendors and get started on the dash so I can get that steering in.. and then brakes... etc etc etc
Decided to order my EFI harness tomorrow, get that ball rolling.. then it just leaves headers and a fuel tank... maybe next month ;)
dropped 2 of the 7" wide slots off yesterday to get fixed up... had a bit of road rash and one was out of round.. so having them fixed.. decided i would bite the bullet and polish them as they wanted way too much to polish... i know its going to take some time.. but hopefully they will shine up!
Thu Jul 19, 2012 9:22 pm |
Not much going on, lots of little things, just ordered my EFI wireharness so thats something. As soon as I get my gauges back from the resto guy i will be ready to put the dash and steering wheel back in.. which will allow me to put the steering shaft, brakes and most of the wiring in and continue the build. I guess i could get started polishing some wheels ;) Oh got the firewall and under cowl area covering in...
Thu Jul 26, 2012 10:47 am |
I am thinking now would be a great time to ad a/c to your resto-mod
Thu Jul 26, 2012 8:50 pm |
dsmith01
Joined: Wed Dec 29, 2010 3:50 pm Posts: 215 Images: 0
_________________ 1972 EB - Fuel Injected 351w, 33s, detroit rear
My Personal Website -
Thu Jul 26, 2012 9:00 pm |
iam thinking $1500 is better spent elsewhere ;)
Thu Jul 26, 2012 9:27 pm |
Got the grill back from the painter, started installing the FORD badge letters which i cleaned then painted with red enamel hobby paint.. polished them up a little, they dont look too bad for being 36 years old. Thats Argent Silver in the center of the grill by the way. Also decided that I didn't like the location where the stock exploder intake was and rather then fiddling around with trying to make some weird connections I picked up a 3" aluminum tube with silicon joiners. I got a reducer for the MAF side to go from the 3.25" MAF connection down to 3". Now i just need the cone filter and the MAF conversion plate.. seen it on ebay but just have to get around to picking it up. I will be cutting the tubing down to put the intake exactly where i want it on the wheel fender. I want to keep the stock overflow bottle and washer so this should work out well. Picked up two of the slots I had fixed and realigned, they decided to do a quick polish one to see how it would look.. so 3 more to go! guess i know what I will be doing this weekend ;) and got my spare wheel blasted and powder coated Argent silver to keep some of the originality with the truck...
Thu Aug 02, 2012 12:06 pm |
Flatheadpopup
Joined: Sat Oct 23, 2010 4:31 am Posts: 94 Location: Colorado Springs
Wow, that wheel polished up nice! Sorry to hear that one of them was out of round...I never ran them and had no idea. You still gonna put the bfg's on them or did you decide to go bigger? Oh, it was nice meeting you by the way.
_________________ 67 Bronco in progress 2.5 lift, 351w, toploader, 4.11s and 33's 65 Mustang...also in progress.
Fri Aug 03, 2012 9:41 pm |
Fri Aug 03, 2012 11:26 pm |
Got a bit more done this weekend.. lots of little stuff mainly.. Ran half of the charging system wires and started to run the headlight wiring.. Also got the intake cut and mounted.. just need to get the MAF adapter and cone filter, also need to cut a hole for the ACT sensor - forgot to do that.. I will need to fab up a little mount for the end of the air intake as I think it wont be happy in there and eventually start moving.. but right now its pretty solid. Cut the top of the PS bracket and ran the upper radiator hose through it along with the high Pressure PS hose. I will be sleeving the radiator hose sooner or later.. just in case. Also installed the plug wire holders.. had to drill them out a bit to get the bolts to fit right. there are a few spots where they are a little close to stuff.. but I will sleeve some of the wired in case they rub.. stuff is already getting tight! Installed the steering column, shift lever and the supports. I should be able to get the dash in with it installed, i really wanted to move along with the engine bay stuff. Also got the heater in place.. gives me a good look at where i can mount the computer... I haven't installed all the ground wires yet, but did install a ground strap from the back of one of the heads to the firewall. I scuffed the firewall across the washer to try and get a good ground connection. Next I will runa ground wire directly to the engine from the battery then the frame and then frame to engine bay body. Next up is to get the aluminum shroud extension made, hook up the transmission lines and figure out why my steering shaft isn't fitting onto the splines..
Sun Aug 05, 2012 9:48 pm |
Looking good! You've made great progress.
Sun Aug 05, 2012 9:51 pm |
D&D72
That thing is looking damned SEXY!
Tue Aug 07, 2012 9:18 am |
Got the fan shroud extension made and installed. I Think the lower radiator hose will work fine but its going to need some plastic covering and a Holder to keep it in place and from rubbing... yes.. i need to get the scratches out of the alumunum harness wont be here until monday :( but I'm sure I can figure out other stuff to do ;)
Fri Aug 10, 2012 11:17 am |
Looking good Chris. Can't wait to see it on the road.
Sat Aug 11, 2012 5:09 am |
Chris, I have your windshield cut and resting safe and sound in my garage. Been rather busy (I am sure you understand). I will look at the schedule and let you know what afternoon this week I can come over and install it.
Mon Aug 13, 2012 8:58 am |
Mon Aug 13, 2012 8:59 am |
Mon Aug 13, 2012 4:34 pm |
Is that just the efi harness or a full kit. I've been really eyeing those.
Mon Aug 13, 2012 5:43 pm |
Wow, that is awesome. So shiny!
Mon Aug 13, 2012 6:00 pm |
Mon Aug 13, 2012 6:04 pm |
Wed Aug 15, 2012 8:36 pm |
Drug the "tub-o-wires" out of the basement last night. Started rooting through for your brake light and decided to just let you do your own digging - like a treasure hunt of sorts.
I plan to be at your place around 6pm or so, with the windshield and the previously mentioned "tub-o-wires". If that still works for you.
Thu Aug 16, 2012 6:06 am |
