It is currently Fri Nov 22, 2024 11:49 pm
[ 8 posts ] |
Soft top, bikini, gas tanks, filler tubes, dual exhaust
HIX
Joined: Tue Feb 15, 2011 12:38 pm Posts: 174 Location: Wheat Ridge Colorado
All are well used
Bikini and soft top appear functional and seem to have most if not all of the hardware. set your expectations accordingly. Bronco hut has spare parts if needed
Tanks and filler tubes are fine, no known leaks. I got them but ended up fixing mine
Dual exhaust- Most of the parts you would need to put together your own true dual exhaust
So I will accept cheap trades such as flat metal sheets or patch panels or simply a nominal donation to CCB
Fri Sep 07, 2012 10:39 am |
75DBE
Re: Soft top, bikini, gas tanks, filler tubes, dual exhaust
I will take the hard top!!!
Fri Sep 07, 2012 11:46 am |
75DBE
I meant bikini / soft top! :-) I got a little too excited!
Fri Sep 07, 2012 11:47 am |
I'll second the soft and bikini tops if 75 doens't end up with them.
Fri Sep 07, 2012 2:24 pm |
Crazyone
Joined: Tue Jan 25, 2011 9:33 am Posts: 207 Location: Aurora, CO
I could use the aux tank and filler tube if it is vented.
_________________ You will not see me cry because I do not sing the blues
Fri Sep 07, 2012 4:08 pm |
75DBE
HIX -- Are you out there anywhere? I am ready to make a run to Wheat Ridge! :-)
Mon Sep 10, 2012 3:17 pm |
HIX
I'm here, just getting my ass kicked at work.
I am in wheat ridge after 5pm and in DTC during the day. 303-521-5082
The aux filler is vented I think.
Mon Sep 10, 2012 4:38 pm |
75DBE
I hear ya! No worries. Maybe I can make my way up there Friday afternoon to pick up the bikini and soft top?
Mon Sep 10, 2012 6:20 pm |
[ 8 posts ] |
