www.ColoradoClassicBroncos.com - View topic - Shop recommendation in Longmont/North ?
It is currently Mon Nov 25, 2024 2:05 am
Reply to topic  [ 10 posts ]
Post Shop recommendation in Longmont/North ?
My '76 with a '96 is out of commission. My regular mechanic is blaming electrical, but he's not an expert on this swap, and doesn't really want to dive into it.
Any suggestions for a place that might be willing and able to help me out?
Thanks much!
Fri Oct 05, 2012 10:04 am
Post Re: Shop recommendation in Longmont/North ?
No idea on a shop, but im guessing someone here should be able to help. What's going on with it?
Fri Oct 05, 2012 2:20 pm
No throttle response. Starts and idles just fine. But any stepping on the gas results in either a stall or nothing at all.
Electric fuel pump seems OK (but I may replace anyway).
Vehicle is new to me. This just started. While I was on the top of the hill at Johnny Park on a shake down trip. At least I was able to idle out of that.
Engine is from a 96 F150, computer form same vehicle. Manifold off a car.
It throws all sorts of codes, of course. But there was some thought about the o2 sensor wiring. Not sure if they traced that yet or not.
Fri Oct 05, 2012 2:52 pm
I am, by no stretch of the imagination, an EFI expert. However, there is one thing that is jumping out at me. A 96 F150 would be an OBD-II computer, and hopefully test port. And if that is the case, the great thing is if there happens to be someone up north that has a copy of AutoEnginuity (Zoso. Paging Zoso) they should be able to plug right in to your truck and tell you what's happening with it.
Sat Oct 06, 2012 10:40 pm
Yes if you are using the obd2 I could come by and give it a scan and see what's going on. I'd check your tps voltage. Let me know if it is obd2 and we can meet up.
Sun Oct 07, 2012 7:45 am
We already ran codes. There are several, since tranny ain't the original, etc. But best guess right now is O2 sensor issues. Not certain I believe that. But I'm dragging it home from mechanics today, and will work on it a bit myself, then give up in frustration, and find a new mechanic.
Mon Oct 08, 2012 8:36 am
Fuel pressure good?
Mon Oct 08, 2012 10:40 am
Fuel pressure is fine.
It's actually using ODB I -- so the wiring isn't "correct" for the engine.
The shop is spending a few hours tracing some wires. Since it was running fine until I went on a bouncy road, the presumption is something disconnected. I just couldn't find it.
Tue Oct 09, 2012 8:36 am
Whew! Found the problem. A ground wire bumped lose and was causing intermittent issues. Easy fix once you've finally found the issue! It's running pretty good now.
Wed Oct 10, 2012 9:50 pm
Nice, glad to hear it!
Wed Oct 10, 2012 10:11 pm
33,022,994 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
