It is currently Sat Nov 23, 2024 6:11 am
[ 27 posts ] |
[Sold] 5.5" Toms Bronco suspension kit
cwin74
Joined: Tue Apr 17, 2012 7:37 am Posts: 139 Images: 0 Location: Broomfield - Colorado
For sale is a never installed (to my knowledge) 5.5" Toms Bronco suspension kit. I've decided to go another route so I have no use for it. I have no idea how old the parts are but they seem to be in good condition even after rolling around in the back of my truck for 7 months. There are chips and nicks on some of the parts from being stored for so long... I was assured all the parts needed to install the kit were included. I'm asking $600 for the kit.
Tue Oct 30, 2012 3:53 pm |
Re: 5.5" Toms Bronco suspension kit
Hmm very tempting. But I'll have to pass as I don't wanna go that high. Its a good deal for someone. Good luck.
Tue Oct 30, 2012 5:39 pm |
Damn! Really tempted here.... not exactly what i was planning.... i was planning 3.5 sl and 1 inch bl.....
Maybe
Someone snatch this up before i do.... please
Tue Oct 30, 2012 7:55 pm |
Dukietown
Wed Oct 31, 2012 9:34 am |
cwin74
Wed Oct 31, 2012 1:05 pm |
Lets talk! Do u have my #?
Wed Oct 31, 2012 3:14 pm |
Go get it Kirk! Hurry.... I keep trying to figure out how I can work $600 into the budget.....
Thu Nov 01, 2012 6:36 am |
Greg - didn't you decide new spring buckets were in the works? You could raise them up and end up with close to the lift you want. You'd have to do the same to the rear tho.
(If I can convince you to build the bronco I want, then I can buy it from you years down the road...)
Thu Nov 01, 2012 7:02 am |
Thu Nov 01, 2012 7:16 am |
Lol - Gotcha! ;)
Thu Nov 01, 2012 7:18 am |
If I did go with a 5.5" suspension lift, would I have to do something to adjust the pinion angle, what about radius arms? Remember, I am running full width axles?
Fri Nov 02, 2012 7:32 am |
The front pinion angle is going to be ok. Its a high pinion D44 right? 5.5" will give you more clearance between the diff & oil pan (or mine hits my exhaust).
The rear pinion angle will probably need adjusted, but that is easy with shims, or if you haven't reset your rear perches to match the EB, do it then.
Fri Nov 02, 2012 7:47 am |
cwin74
Re: 5.5
Fri Nov 02, 2012 7:48 am |
Fri Nov 02, 2012 7:51 am |
Fri Nov 02, 2012 8:21 am |
Fri Nov 02, 2012 9:18 am |
The 78/79 axles have a little more caster built into the front axles than EB axles. So you'll have to put it together & measure to figure caster. Long arms will help with caster, but you should be able to correct with degreed bushings & regular arms.
Fri Nov 02, 2012 9:46 am |
BNC04
hmmmmmm,, I'm sitting on a rock hard supposeded 3.5" superlift. But I measure 11" from top of the front axle to the bottom of the frame now. Any thoughts if this lift would settle into that same range or would I gain another true 1 and 1/2? Brett
Fri Nov 02, 2012 10:26 am |
cwin74
Shameless bump.
Mon Nov 05, 2012 11:06 am |
cwin74
I'm sick of staring at the of suspension parts in my garage. First $450 takes this kit home. I'll leave this open for a week before dealing with the 'chuckle-heads' from CL then the price will be going back up to $600. I would rather see this go to a CCB member.
As I said before, "I was assured all the parts needed to install the kit were included." That being said it most likely has everything you need.
Wed Feb 13, 2013 12:35 pm |
cwin74
Sold!
Wed Feb 13, 2013 5:27 pm |
Colorado75bronc
Re: [Sold] 5.5" Toms Bronco suspension kit
Ok who bought it? Zack?
Wed Feb 13, 2013 11:26 pm |
Not i. But not for lack of trying. My money is on Kinder.
Wed Feb 13, 2013 11:49 pm |
TIM
Joined: Sun Nov 07, 2010 9:54 pm Posts: 41 Location: Denver
It will be on my bronco on Saturday hopefully, I'll take a before and after. It should be a huge altitude adjustment from the sagging stock 68' setup
Thu Feb 14, 2013 1:08 pm |
Good score. Looking forward to seeing the finished product. 5.5" was a little high for my goals, but at that price it was too tempting for me not to make a try for it.
Thu Feb 14, 2013 2:04 pm |
I'm kinda a documentation geek and measure things like height at all four corners now and again after the lift, and also approach and departure angles...
But before and after pics work just as well.
Fri Feb 15, 2013 2:45 am |
I just want to thank you for buying this before I had to and ended up sleeping in the garage with my bronco on Valentines Day.
Fri Feb 15, 2013 7:39 am |
[ 27 posts ] |
