www.ColoradoClassicBroncos.com - View topic - 69 Dudes-- Just the beginning
It is currently Wed Dec 04, 2024 2:58 am
Reply to topic  [ 405 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 14  Next
Post Re: 69 Dudes-- Just the beginning
Sat Mar 30, 2013 5:42 pm
Missed you today at the swap meet, skis are looking good!
Sat Mar 30, 2013 9:25 pm
Sat Mar 30, 2013 9:41 pm
Didnt get there till about 9, was parked west end, couldnt stay long either
Sat Mar 30, 2013 11:26 pm
That is exactly how we did it (floor jack), but I did say we, so it was a bit easier with another set of hands. Nice work!
Sun Mar 31, 2013 6:26 am
Big thanks to Kinder, dropped it off with Plumbdoctor this morning for its fresh new look. Now to sit tight and watch paint dry...
Sat Apr 13, 2013 4:17 pm
Well if there was anything I want to sit and watch the paint dry, an EB is it!
Mon Apr 15, 2013 1:45 am
So after quite a few days of running into alignment issues, chasing electrical gremlins, installing power steering, and fighting May snow storms to try and paint, Orenthal James made his first drive around the block. A few more minor things to get done but should be trail ready in no time!
Sat May 11, 2013 7:51 am
That's awesome! Looks great!
Sat May 11, 2013 10:46 am
Nice looks good!
Sat May 11, 2013 11:51 am
We need some daylight shots to show off the hood stripe.
Sat May 11, 2013 5:59 pm
Unfortunately, no new pics yet-- I ran into a few issues last night...
So I went to drive it home yesterday and was having a few issues. The engine was not getting much power when climbing any sort of incline and anytime I gave it a substantial amount of gas, it would sputter and skip. The other thing is that we have had a female K9 of a time bleeding the newly installed power steering. It is still noisy and chirping and does not turn the wheel real smooth. My first guess with the power is that the carb is gummed up and needs a refresh-- but I am wondering if maybe one could have something to do with the other. It feels like as soon as you try to open it up, it is choking out. I am still not sure why we can't get the PS to bleed out though.
Thoughts?
Sun May 12, 2013 7:50 am
PS systems can take a bit of time to bleed, especially if you install hydroboost. It's recommended, or so I've read, that to bleed the system you should:
Put the front axle on jack stands
Ensure PS pump is full
Start engine
Slowly turn steering wheel from lock to lock 3-4 time or so
Turn engine off
Check PS fluid level, top off as necessary
Start engine and repeat
Never pull wheel hard to lock as this can damage the worm gears if you've got a significant air bubble in there
All in all, it can take a bit of driving after doing this before the system is completely bled, but this will at least get you most of the way done.
As to the lack of power issue, how much vacuum are you pulling at idle?
Sun May 12, 2013 8:53 am
We definitely did not have the front end up when bleeding-- in fact, we had the front end sloping down on the driveway when we first attempted bleeding the system. Also, not real sure on the vacuum pressure-- how do you check that? It does start up and idle fairly well. It smells a little rich and reaks of gas after left on for a while...
Sun May 12, 2013 1:21 pm
What carb are you running? I'll snap a quick pic.
You'll need a vacuum gauge. Not too expensive and always handy to have around.
Sun May 12, 2013 4:52 pm
If its Edelbrock, you'll want to hook that vacuum gauge up to the port on the right (capped one).
Sun May 12, 2013 5:01 pm
It is a holley and I am not sure I have an extra port to check. I used the last one for the Power Brake Booster. The brakes work fine so I am guessing that it is something with the carb itself and maybe the pump for the power steering. I am going to have the carb rebuilt tomorrow and see how that does.
Sun May 12, 2013 9:56 pm
In my limited experience, Holley's can be great carbs, but are very picky about how they are adjusted. Seems they have to be dead nuts on (whatever that means) to run right, but when they do....
Mon May 13, 2013 12:15 am
FrankCastle-- thanks for the responese.. Rebuilt Carb today and the choke had been stuck on closed... now runs much better! Bought a new steering pump and having PlumbDoctor install that while I am out of town to see if we can get the steering to tighten up. Some better pics to show off the new paint, rockers, flares, mirrors-- basically new exterior...
Very close to an official unveiling!! fire fire
Mon May 13, 2013 9:03 pm
Steering pump to tighten the steering? Not sure I follow you there unless you are still trying to get bubbles out of the system?
Tue May 14, 2013 12:16 am
Tue May 14, 2013 7:18 am
OK, I follow you. Just didn't want you setup for disappointment. But air in the system will make it feel loose. I remember probably running the steering wheel back and fourth 100 times after Hydro Assist.
Tue May 14, 2013 8:00 am
looks really good. you guys have made a lot of progress in just the couple of weeks since I put in the new windshield. Awesome job!
Tue May 14, 2013 9:56 am
Tue May 14, 2013 11:35 am
Good looking paint. I have a similar stripe around the raised section of the hood, mine is white on blue (on yellow, on rust). I don't think I've seen many that way.
Great news on the carb issue.
Tue May 14, 2013 5:23 pm
Was able to get the old purple tint removed and got the Bronco re-tinted on Friday. As soon as the bikini top arrives from Tom's, I will be ready to go topless! Planning on installing the rear seat this week. I also have a 23 gallon tank to swap in for the stock tank-- anyone have any advice on how to do it or is it pretty straight forward?
Mon Jun 10, 2013 8:35 am
Tank install is pretty straight fwd, what type of mounting does it use, track or bolt?
Mon Jun 10, 2013 11:06 am
Mon Jun 10, 2013 11:46 am
I'd use something besides water, maybe acetone.
Mon Jun 10, 2013 2:30 pm
x2 acetone will work I used that and then stuck my hand in the tank and wiped out what I could reach after sloshing acetone around for a bit.. used brake cleaner to do a final wipe.. amazing how much crap is in those new tanks..
Mon Jun 10, 2013 7:03 pm
33,209,229 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
