It is currently Mon Nov 25, 2024 8:49 pm
[ 9 posts ] |
Do I want a horizontal band saw?
So I already have a 14" abrasive chop saw for cutting metal. Our local paper has had a horizontal bandsaw for sale for a couple weeks. It's about 50% the price of new ones, according to a quick Google. What is the advantage over my chop saw? I like adding to my arsenal, but only if its something I will use.
Fri Apr 05, 2013 11:37 am |
Crazyone
Joined: Tue Jan 25, 2011 9:33 am Posts: 207 Location: Aurora, CO
Re: Do I want a horizontal band saw?
Horizontals are great, way more versatile than a chop saw. They are great for sheet metal and bar stock, alloys and plastics. Plus with a band saw you are cutting material and with a chop saw you are grinding material. Chop saws are limited in what you can cut both in material and size. The only advantage a chop saw has is it will work on harder materials and is compact.
_________________ You will not see me cry because I do not sing the blues
Fri Apr 05, 2013 12:01 pm |
They're really different beasts. As Crazy said, most band saws will cut larger stuff. Band saws are likely to be more accurate if set up well.
Sat Apr 06, 2013 12:20 am |
If I had to choose, I think I'd go with a band saw too. The friend of mine who helped me install my Atlas had one and it was cool to walk over, setup the metal on the saw, start it and walk away. It would shut off when the cut was done, with far less noise, mess, and way cleaner cut. A great tool to have around if you're doing a moderate amount of metal cutting.
Sun Apr 07, 2013 7:44 am |
Thanks for the advice. I brought it home. Now that I've seen how it works, I'm sure it will be my "go to" metal cutter. Needs a blade, but otherwise in good shape.
Sun Apr 07, 2013 12:44 pm |
sbolt19
My dad has a horiz. band saw that we use all the time. Use it almost as much as the plasma cutter. You won't be sorry you bought it.
Mon Apr 08, 2013 11:32 am |
Crazyone
Good get! Make sure you get a good quality blade. Saves a lot of time and aggravation.
Mon Apr 08, 2013 11:57 am |
So I wanted to update this. I haven't even used it much, maybe 10 cuts. It's waaaaaaay better than a chop saw. More accurate, less noisy, and no shower of sparks. Money well spent.
Sat Jul 13, 2013 8:40 pm |
Bandsaws rock, I bought a porta bandsaw at the Murdoch sale and love it.
Sat Jul 13, 2013 9:44 pm |
[ 9 posts ] |
Users browsing this forum: No registered users and 78 guests |
