It is currently Sat Nov 23, 2024 4:13 pm
Re: Big O
Got the roll bar mocked in tonight, we were originally going 2 use a bolt-in bar with legs that went to the tailgate, but changed our minds and went with a welded short leg that goes to the tops of the wheel wells. Hope 2 pick up seat belts tomorrow and let boy drive it to school on Friday. Run for your lives!
Wed Apr 10, 2013 8:55 pm |
Re: Big O
http://www.youtube.com/watch?v=geHLdg_VNwwOK, I know it only sort of fits, but now it's stuck in my head so it had to be posted.
Wed Apr 10, 2013 9:40 pm |
Re: Big O
Ernie at 4 Wheel Parts in Westminster was able to get me a really good deal on seatbelts if your interested.
Wed Apr 10, 2013 11:32 pm |
Re: Big O
Heading out on our maiden voyage, I'll post up pics & video if it makes it, even if we tow it home.
Sun Apr 14, 2013 6:37 pm |
Lobobronco
Joined: Wed Sep 29, 2010 9:20 am Posts: 289 Location: Denver, CO
Re: Big O
Woohoo! Can't wait to hear how it went!!
Great news!
Matt
_________________ Her name is Lucy...and well...that's who she is!
Sun Apr 14, 2013 7:42 pm |
Re: Big O
That's great! Hope all goes well.
Sun Apr 14, 2013 7:56 pm |
Re: Big O
Well I think it was a success, a couple of problems popped up, we'll sort those out over the next couple of days. Pic, 1st stop... Fuel! ImageUploadedByTapatalk1365993625.963471.jpg And of course we couldn't go home without seeing some smoke! http://youtu.be/P6fcZ9TMtb4
Sun Apr 14, 2013 8:41 pm |
Re: Big O
Sweet-- congrats! Always a rewarding feeling and you'll never forget your first ride!
Sun Apr 14, 2013 9:35 pm |
Re: Big O
That's awesome. I'll try to stop in at the tint place we were PMing about to see if I can swing a deal for you.
Sun Apr 14, 2013 10:10 pm |
Re: Big O
ha super sweet.. great burn out!
Sun Apr 14, 2013 10:27 pm |
Re: Big O
one tire fire!!!!
Good job guys. I bet there is a smile that wont go away. Im jealous and wish mine was done and driving.
Mon Apr 15, 2013 6:13 am |
Re: Big O
Sweet!
Mon Apr 15, 2013 6:57 am |
Colorado75bronc
Re: Big O
Looks awesome guys!!
Mon Apr 15, 2013 1:44 pm |
Woodscaper
Joined: Fri Nov 19, 2010 11:16 pm Posts: 587 Location: Lakewood/Green Mtn.
Re: Big O
Very Nice job! All the hard work paid off.
Sun Apr 28, 2013 8:52 am |
Crazyone
Joined: Tue Jan 25, 2011 9:33 am Posts: 207 Location: Aurora, CO
Re: Big O
Love the color! Awesome 1st ride for a High Schooler.
_________________ You will not see me cry because I do not sing the blues
Mon Apr 29, 2013 8:30 am |
Re: Big O
I had no idea you guys would have it done by the Birthday deadline but it looks like you guys hit the deadline and created an amazing Bronco. Keith did a great job painting. Love the color, wheels, tires, lift, etc. Beautiful Bronco and whole project came together.
Congrats on the new Bronco and Happy 16th Birthday!
Tue May 14, 2013 10:43 am |
Re: Big O
Phil shows up with shiny parts, Phil gives much needed instruction to 6' 3" bronco owner, Phil cracks jokes, Phil takes test drive, now all is right with Bubba Smurf.
THANKS A TON PHIL!
Sun May 19, 2013 9:19 am |
Re: Big O
Best way ever to replace a trans
Sun May 19, 2013 3:11 pm |
Re: Big O
Thats just cheating there.
Mon May 20, 2013 8:35 am |
Re: Big O
Bubba Smurf is getting an alignment check, I'll guess the following are out; track, camber, caster & toe. I'll also guess that the caster & toe are close and that we won't be getting the $69 special price.
I think the front axle has a slight bend the way the camber looks on one side because the ball joints are in good condition.
Tue May 21, 2013 3:33 pm |
Colorado75bronc
Re: Big O
You can always buy the degreed eccentrics for the upper balljoint, do you know if you can still get the spindle camber shims?
Tue May 21, 2013 7:42 pm |
Re: Big O
i might have some dana44 upper ball joint sleeves that you can adjust.. i will look..
Tue May 21, 2013 9:33 pm |
Re: Big O
Corey, I have a set of those camber shims, Willem won them at the Memorial fun run, so we will be putting one of them them in.
Chris, if you have a set I'd like to pick them up as well for the caster.
Turns out the whole tuck is out slightly for all measurements including the rear axle. We need more caster, even though I put in the correct C bushings for the lift, camber is okay on the driver side but I need 1 degree on the pass side, I need to dial in a bit more toe in (the easiest to fix) and finally I need to try to twist the rear axle counter clock wise from a top view look of the truck. All the bushings for the entire suspension were replaced, new ball joints & new steering components were installed when we built it so I guess I should expect some tweaking.
It drives well for a bronco, but with a 16 yo behind the wheel I'm going to try and get it to drive as safe as possible. I'm going to get it up to speed now that we have the trans sorted out and see what shakes loose.
Wed May 22, 2013 7:01 am |
Re: Big O
sure will arrange to drop them off or if your in the neighborhood
Wed May 22, 2013 7:50 am |
Re: Big O
Wed May 22, 2013 1:11 pm |
Re: Big O
And I would love to grab that body lift from you as well. Hoping to get the tub out of the yard this weekend... (if it does not work out - no biggie, I have plenty of hockey pucks I can use for mock up purposes)
Wed May 22, 2013 1:13 pm |
Re: Big O
sure iam around today and friday
Wed May 22, 2013 1:54 pm |
Task Force Bronco
Re: Big O
Went down the highway at 90 mph in bubba smurf ran like a champ even with a tired 351 still pulls like no other. Video soon to follow.
Mon May 27, 2013 3:35 pm |
Re: Big O
Sporting the summer look, still have to sort out the snaps, but the safari look is a keeper.
Thu Jun 20, 2013 12:03 pm |
Re: Big O
Sweet! Glad you got the header rail sorted!
Thu Jun 20, 2013 8:32 pm |
