It is currently Mon Nov 25, 2024 3:27 am
[ 10 posts ] |
Odd ball electrical question
Wish I had a picture to help explain, but I'm 60 miles from my Bronco.
Inside the front driver door post of my Bronco is a do-dad with two wires runnin out of it. This do-dad has a Ford part number on it and is held in place by two screws. Anyone know what I'm talking about and has a clue what this thing does? Or rather what it is supposed to do?
Sun May 12, 2013 12:21 pm |
Re: Odd ball electrical question
The actual door post or the inner fender? Only thing in that area that I know of is the radio antenna, but that goes through the kick panel / inner fender.
Sun May 12, 2013 4:14 pm |
Door post.
Sun May 12, 2013 4:58 pm |
Colorado75bronc
Ya that's on Todd's as well but no wires to it
Sun May 12, 2013 5:09 pm |
Viper knows exactly what it is. I believe he said it was a temp sensor for something. They are only available on 1 year. If you look at all later broncos they have a grommet plug there.
Sun May 12, 2013 7:40 pm |
Maybe for the remote control mirror?
Sun May 12, 2013 7:52 pm |
I do believe the temp thing rings a bell. Maybe saw it in a wiring diagram on day.
Sun May 12, 2013 8:50 pm |
Derka derka. No idea how THAT works, but appears to be the suspect in question.
Sun May 12, 2013 8:53 pm |
Sun May 12, 2013 10:42 pm |
That site has some good stuff, I used it a couple of times on Willem's build.
Mon May 13, 2013 6:30 am |
[ 10 posts ] |
Users browsing this forum: No registered users and 16 guests |
