www.ColoradoClassicBroncos.com - View topic - Rear Explorer Brake question
It is currently Mon Nov 25, 2024 3:59 am
Reply to topic  [ 7 posts ]
Post Rear Explorer Brake question
So I had a leak from my proportion valve for the rear brakes that i fixed this evening and was about to bleed the rears when I noticed the bleeders were below the brake lines. Now call me crazy (but not shirley) however are the backing plates on the wrong side? Most of the time calipers are mounted to the upper rear of the rotors, at least most of the ones i have installed or seen.
I haven't looked at any directions for installation as I'm not sure where the rear brake conversion was purchased (maybe BC or WH?) Am I correct in in assuming these are on the wrong sides and i will have to pull both axles and backing plates then remount them on the opposite sides with the ebrake cable at the top?
Mon May 20, 2013 8:45 pm
Post Re: Rear Explorer Brake question
I think you got your answer on ACB. Sorry for the bad news.
Tue May 21, 2013 1:47 am
the bad news would be I could never get hte air out of the system.. or worse they failed.. its an easy fixed just kind of a pain.. and going to be messy with gear oil dumping out but rather have it fixed and know its fixed. At least all the bolts are tight... which is not what I can say about allot of other stuff on this truck, I keep finding stuff that has moved, loose or not tight..
Tue May 21, 2013 7:34 am
And done didn't take that long ;)
Tue May 21, 2013 11:58 pm
[quote="landshark"]....didn't take that long ;) quote]
Says the guy who did a near frame off restoration in, what, a month? Two? What did this take you? 15 minutes? Lemme know what you need for me to borrow that machine that makes time standstill so I can get some work done on mine.
Wed May 22, 2013 12:11 pm
ha 15 min i wish.. i woudl have had the front fender repainted.. brake fluid = corrosiveness..
i think it took me 2 hours.. give or take.. did a few other things too
Wed May 22, 2013 1:49 pm
Wed May 22, 2013 2:04 pm
Users browsing this forum: No registered users and 25 guests
33,026,866 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
