www.ColoradoClassicBroncos.com - View topic - Tire Deflators
It is currently Fri Nov 22, 2024 2:45 pm
Reply to topic  [ 8 posts ]
 Tire Deflators
Post Tire Deflators
I bought these a few years back and never really used them. Paid $50 for them and will take $25.
Fri May 24, 2013 1:11 pm
Post Re: Tire Deflators
ill take em if they will work with my 35's. they are adjustable? What PSI range?
Fri May 24, 2013 5:31 pm
They work on all standard valve stems. There is a chart included that shows the lowest pressures recommended for tire size and weight it supports. The lowest pressure on the chart is 4 psi. There is a hex set screw that adjusts the pressure.
Fri May 24, 2013 6:57 pm
If they don't work for Landshark I'll take them.
Fri May 24, 2013 7:23 pm
Mike they are yours if he passes.
Fri May 24, 2013 10:18 pm
I'll take em ;)
Fri May 24, 2013 10:51 pm
Chris, I'm going to Don's place tomorrow and can grab them for you.
Sat May 25, 2013 12:18 pm
That would be great. If you happen to see a window crank grab it ;)
Sat May 25, 2013 1:06 pm
Users browsing this forum: Google [Bot] and 42 guests
32,952,413 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
