[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4794: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4796: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4797: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4798: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) www.ColoradoClassicBroncos.com - View topic - Oops! Power steering leak when trying to adjust belt
Author
Message
laffycaffi
I was going to try to tighten my PS belt to reduce the squeal I was getting when turning. So I loosened up the bolt on the left of the reservoir mount to try to tighten.
Then suddenly the PS fluid started to drain. I re-tightened and it continued to drain. Yikes. Did I damage something?
I'm looking for ideas and suggestions. I have no real idea what my next step ought to be. Thanks
Sun May 26, 2013 1:01 pm
airbur
Re: Oops! Power steering leak when trying to adjust belt
Sounds like you have a loose hose maybe? Take a picture of your setup and the bolt you tried to take out.
