[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4794: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4796: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4797: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4798: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) www.ColoradoClassicBroncos.com - View topic - Timing chain gear bolt
So I have pulled the timing chain cover of my 302 to start putting on my explorer stuff. The timing chain cover for the explorer is thinner so I have to pull of the cam that the fuel pump arm rides on. Due to taking that off the bolt is now to long and the wash now hits the guide pin. Is there a new wash and bolt I can get for a set up that doesn't use that cam for the fuel pump? Or any other solutions?
Tue Jun 18, 2013 7:43 pm
plumbdoctor
Re: Timing chain gear bolt
Grind the pin down a bit, tighten bolt... You might have to clearance the bolt a little as well
