It is currently Mon Nov 25, 2024 8:49 pm
[ 6 posts ] |
220v adapter
Just confirming what I've tracked down elsewhere since the interweb info isn't 100% consistent. I need to make an extension cord for my welder to run it off my dryer outlet. 4 prong dryer outlet, 3 prong welder. The diagram below is correct, right?
Sat Jun 22, 2013 12:44 am |
Re: 220v adapter
correct except your white while is also a hot. 3prong 220 doesn't have a neutral.
Sat Jun 22, 2013 5:42 am |
Re: 220v adapter
what size wire are you using and what distance?
Re: 220v adapter
30ft and 10ga. The welders manual calls for 12ga and a max of 50ft, I figure this will give an added margin. Mine may have a white wire, there is a good chance I'll repurpose a 110 cord. I might sharpie the wire black just to stay closer to code.
Sat Jun 22, 2013 7:59 am |
Re: 220v adapter
You can run regular 110v (black/white/ground) wire as 220v. I've done it a few spots in my house, bathroom heat, irrigation pump, and my compressor. No recolor coding. In 4 wire 220v the "other" hot line would be red.
Sat Jun 22, 2013 8:07 am |
Re: 220v adapter
Thanks for the help, guys. Got the cord made up today and testing it didn't let any smoke out of the welder.
Sun Jun 23, 2013 6:37 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 87 guests |
