It is currently Mon Nov 25, 2024 8:36 pm
[ 17 posts ] |
Axle cleaning
I'm planning to thoroughly refurbish and paint my FW axles before installation. What's the best way to clean them up? Obviously I can have them sandblasted, anyone have a rough idea of what that costs or who in the Metro area would do a good job for a reasonable price? Anything else that can be done that would be as effective without spending the money? Finally, anyone have anything they like better than POR-15 for paint?
Tue Aug 13, 2013 10:02 am |
Colorado75bronc
Re: Axle cleaning
Plenty of degreaser, a scraper, wire brush and hotsy pressure washer works great
Tue Aug 13, 2013 10:26 am |
trei75bronco
Joined: Wed Jan 26, 2011 10:55 pm Posts: 837 Images: 0
Re: Axle cleaning
Most of the media blast places I have found wont touch a greasy axle... I spray the crap out of it and take it to a car wash. Power wash it and.scrap the crap out of it.. then at home your wife doesn't say. What is that pile of grease doing in the street or lawn :-) makes it easier for sure
Tue Aug 13, 2013 12:43 pm |
Re: Axle cleaning
Oven cleaner and a pressure washer.
I used Chassis Saver with good results. Degrease, wire brush loose junk off, paint. Done.
Tue Aug 13, 2013 5:31 pm |
Re: Axle cleaning
x2 oven cleaner and pressure washer..
i did take the rear 9" into Blastech - after i degreased it - I wanted to make weld it up and leak free and figured stripping it would allow me to make it nice.. and it did.
i think it cost $50 just call and ask gary
Tue Aug 13, 2013 9:13 pm |
Re: Axle cleaning
Another option for sand blasting is headstone engravers. I had a bumper done by one. Sandblasting places wanted over $100. I think I paid $30.
I would also run a broomstick with a rag down the tubes a few times. Chimney sweep??
Wed Aug 14, 2013 1:55 am |
Re: Axle cleaning
Thanks guys, that helps. JD, I may have some hookups with the headstone folks, thanks for the tip.
Wed Aug 14, 2013 10:52 am |
Re: Axle cleaning
Wed Aug 14, 2013 2:03 pm |
trei75bronco
Re: Axle cleaning
Has to be a Pomeranian kitten I think...
Wed Aug 14, 2013 9:53 pm |
Re: Axle cleaning
I heard you had to dip the kitten in acetone first.
Wed Aug 14, 2013 9:59 pm |
Re: Axle cleaning
Wow, Justin that's animal cruelty. I use Simple Green.
Sorry, there is someone on CB.com that has a signature about pulling a kitten through an axle tube to clean it. I must be the only one who has noticed it. It always makes me laugh.
Wed Aug 14, 2013 10:12 pm |
Re: Axle cleaning
I guess it did take a bit of a dark turn. Hopefully PETA finds this thread. You should hear the things we say at work.
Wed Aug 14, 2013 10:50 pm |
trei75bronco
Re: Axle cleaning
Not acetone. Muratic acid works great etches too
Thu Aug 15, 2013 8:50 pm |
Re: Axle cleaning
You are putting the cart before the horse here guys...it has to be the neighbors cat.
Mon Aug 19, 2013 9:44 am |
Dirtheadz
Re: Axle cleaning
X3 - Oven cleaner and a pressure washer.
Mon Aug 19, 2013 10:49 am |
Re: Axle cleaning
Mon Aug 19, 2013 2:18 pm |
Re: Axle cleaning
Sounds like oven cleaner is the clear winner. Seems like it would be easier to dip the cat than spray it, though.
Mon Aug 19, 2013 10:17 pm |
[ 17 posts ] |
Users browsing this forum: No registered users and 83 guests |
