It is currently Sat Nov 23, 2024 6:34 am
69 Dudes-- Just the beginning
Yes, water takes too long to evap.
Tue Jun 11, 2013 1:55 am |
Installed the rear seat after finding out the first one was defective.
Tue Jun 18, 2013 7:53 pm |
Went topless this weekend. Was also able to get the front part of my role cage bolted in, install the bikini top, and make some repairs to the internals of the driver's side door.
Mon Jun 24, 2013 2:53 pm |
White bikini top, fairly uncommon, nice complement to your trucks paint scheme, I like it.
Mon Jun 24, 2013 7:14 pm |
Agreed, that top looks great.
Mon Jun 24, 2013 8:02 pm |
Thanks guys-- as long as it "stays" white! Not to toot my own horn, but I am very happy so far how things have turned out. Keith aka Plumbdoctor did a great job with the paint and I am sure that after the summer and he does some touch ups and buffs it out, its gonna look even better. Now I just need to get motivated to re-wire the dang thing so I can get a stereo in there.
I know I have said it before, but thanks to both of you guys, Justin and Kirk for your help through the winter. I wouldn't have come close to the progress without your help and direction in particular.
Mon Jun 24, 2013 9:19 pm |
Colorado75bronc
Looks awesome
Mon Jun 24, 2013 9:20 pm |
plumbdoctor
OJ gets a Beenie... Looks good, now get the harness and we'll put it in over here when "we" flip the turd back over
Mon Jun 24, 2013 9:43 pm |
Mon Jun 24, 2013 10:38 pm |
plumbdoctor
Yep, only down time is watching the paint dry
Wed Jun 26, 2013 10:20 pm |
Wed Jun 26, 2013 11:08 pm |
A few snapshots from Orenthal's first trail ride.
Mon Aug 19, 2013 12:54 pm |
Looks like a happy dog, nice!
Mon Aug 19, 2013 10:21 pm |
Error404
Joined: Fri Aug 16, 2013 8:33 am Posts: 92 Location: COLORADO SPRINGS
How is the liner in the engine bay holding up? I've always wondered how it does with heat.. I've wanted to do it with mine.. since mine has no motor no trans now is the time to spray it.
_________________ 1996 bronco 4bt sas . 1972 bronco 10k mi no motor no trans..unfortunately rolled in 1973. Left for me to bring back from the dead.
Wed Aug 28, 2013 5:54 pm |
Geologist
Great looking Bronco!
_________________ 1966 Bronco, rebuilt 302, Twin shift Dana 20, T19, 3.5 suspension lift, 2 inch body, 35x12.50 tires
Wed Aug 28, 2013 6:14 pm |
Thu Aug 29, 2013 8:03 am |
Was going through a bunch of boxes of junk during my move this last week and found some gems! This was my first Bronco-- my parents bought it for me my Senior year of HS back in 1996-97. I had it through my Freshman year of college and then sold it because I couldn't get it to pass emmissions and wanted something a little more commuter friendly. Man I wish I would have had the foresight to hang on to it though! It was also a 1969. Had I think a 3" suspension lift, 302, 3 spd on the floor. Loved that thing! It even made an appearance in my Senior Year Class video. Final shot was us driving into the sunset on the old Daniels Park Road ( I went to HR high school when HR was still a little country)-- and we threw our graduation caps in the air with the top off.
Tue Dec 03, 2013 11:27 am |
Colorado75bronc
Looks really clean! Nice!
Sent from my iPhone using
Wed Dec 04, 2013 7:10 pm |
Started working on the dash. Bought the dash overlay from JBG and cut out most of the middle section. I then cut out the old glove box and am welding that piece in over 5 inches so that it won't hit the roll cage. I plan to move the gauge cluster to the other side of the steering column. Keeping the heater controls in the same place.
Sun Feb 09, 2014 6:19 pm |
Had a friend who shortened his dash on either side by a couple of inches, allowing the roll cage to fit much tighter to the windshield and giving better ingress and egress. If I re-do my dash, this will be part of the project.
Mon Feb 10, 2014 3:02 am |
Took the dash to get a couple holes water jetted. Decided to get the vintage tachometer from WH and mount it in the dash. So the speedo and tach holes will be cut by this weekend. Also started my heater rebuild. I had gotten a new blower and squirrel cage for Christmas and it's a lot bigger. Had to cut a larger hole. Also grinded out all of the rust and am ping some new paint on the heater parts. I did purchase a new seal kit so I am hoping this thing will be a serious upgrade when all said in done. I haven't done any research... YET... But is there an upgrade to the actual heating unit or do I replace that stock?
Mon Feb 17, 2014 11:53 pm |
The heater core is a stock replacement. Good call on the tach, I've been eyeballing one of those. they're sweet.
Tue Feb 18, 2014 1:22 am |
I can vouch for the heater upgrade. It is a huge improvement. New "low speed fan" = old "high speed fan". New "high speed fan"= actual defrosted windows and actual heat you can feel.
I did mine in the truck (not recommended) when I turned it on, 40 years of accumulated dirt blew out my defrost ducts.
Tue Feb 18, 2014 8:12 am |
Mon Mar 03, 2014 11:37 pm |
That looks really good! Curious to see how it turns out. I'd be tempted to use some bondo or something to blend those spacers in and make them look really nice.
Mon Mar 03, 2014 11:57 pm |
I am jealous as that should sound really nice! Someday I'd like to upgrade my system. Marine grade is a good way to go. If tower speakers for boats weren't so bulky I'd be tempted to run them. But then I think to myself it's just a rock crawler...
Tue Mar 04, 2014 3:59 am |
Just received email that my gauge has been restored and is en route back to CO.
Before: Gauge Before.jpg
After: Restored Gauge.jpg
Will be here just in time for the rewire this weekend!
Wed Mar 05, 2014 10:12 am |
That's so awesome! Someday I hope to do the same!
Wed Mar 05, 2014 10:25 am |
2k more miles and mine will be headed off for the same treatment.
Wed Mar 05, 2014 10:52 am |
Wed Mar 05, 2014 12:58 pm |
