www.ColoradoClassicBroncos.com - View topic - 4th Annual Platte River Bar and Grill Meet and Greet
It is currently Sun Nov 24, 2024 6:46 am
Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3  Next
Post Re: 4th Annual Platte River Bar and Grill Meet and Greet
Tue Oct 01, 2013 5:42 am
Jeff, we'll pick up some extra ribs, but can't guarantee how many we'll have left when we get back to Colorado-it's a long haul!
Doug
Tue Oct 01, 2013 6:06 am
Ill most likely be there.
Tue Oct 01, 2013 9:30 am
I should be able to make this! Depends on this week with work.
Tue Oct 01, 2013 9:43 am
This is going to be on Sunday Correct? I had it in my head that it was Saturday because breakfasts are normally on Saturdays. Just clarifying before I drive an hour down on the wrong day!
Tue Oct 01, 2013 7:15 pm
Yes, this event is on Sunday. I spoke with the restaurant today to confirm everything and they agreed.
Tue Oct 01, 2013 7:17 pm
You can count me in.
Tue Oct 01, 2013 10:33 pm
Still no baby yet. Wife is now 7 days past due. Making this one is not looking good...
1966 Bronco, rebuilt 302, Twin shift Dana 20, T19, 3.5 suspension lift, 2 inch body, 35x12.50 tires
Wed Oct 02, 2013 7:35 am
Wed Oct 02, 2013 4:47 pm
Wed Oct 02, 2013 4:55 pm
Duh! Just bring her with you. There's hospitals everywhere if you need to stop in on the way home.
Wed Oct 02, 2013 5:54 pm
Wed Oct 02, 2013 6:03 pm
being that overdue is strange that they havent induced her yet.
Wed Oct 02, 2013 6:27 pm
Wed Oct 02, 2013 8:06 pm
I'd love someone to follow... Just in case I have some hiccups.
Wed Oct 02, 2013 8:41 pm
Wed Oct 02, 2013 9:31 pm
I'm in Park Hill. Could meet off I-70 or 6th and Santa Fe.
Wed Oct 02, 2013 10:07 pm
Fri Oct 04, 2013 1:15 pm
Sat Oct 05, 2013 10:00 am
Im out, finally got the motor built and installed, started it thrusday night everything went good until i lost oil pressure. Thinking a main bearing but not sure yet. banghead banghead banghead
Sat Oct 05, 2013 10:47 am
Sat Oct 05, 2013 10:51 am
I'm out. Work wins again.
Sat Oct 05, 2013 11:02 am
Hope it is not too late, I will be there.
70 Bronco - '88 EFI 5.0 w/ RJM harness, JB Fab Twin Stick D20, AOD w/Art Carr shifter, 3.5" WH lift on 33s, 4.11s. Mods: Chevy disks in front, hydroboost parts laying in garage.
Sat Oct 05, 2013 12:32 pm
I'll be there too, probably not in Bronco though.
Sat Oct 05, 2013 12:43 pm
I will be there too with 76fordbroncogirl.
Sat Oct 05, 2013 12:54 pm
Sat Oct 05, 2013 12:59 pm
Well could you add 4 more. Who is heading up from the springs?
Sat Oct 05, 2013 8:12 pm
Yup, looking forward to seeing you!
Sat Oct 05, 2013 8:23 pm
I'll be there with mi familia !
Sat Oct 05, 2013 9:27 pm
We still plan on being there but we could be without Bronco shrug shrug . I have not driven the Bronco for a couple weeks because I had the transfer case drained to fix a leak and had to wait for a new gasket. Anyway, went for a ride tonight and it drove great for a few miles then started popping and backfiring. I also smelled melting plastic aroma. The melting plastic turned out to be the oil pressure sending wire falling against the header. Took care of that but the problem persisted. I noticed the fuel pressure gauge was bouncing, just a few PSI up and down but didnt remember it doing that before. I also changed the fuel pump relay because it seemed warm. Still no change but I tried switching from the Aux. fuel tank to the Main tank and it seems to be fine. The main tank is full and the Aux tank gauge reads 1/4 tank but I'm wondering if its not really almost empty and sucking air. I'll run over and fill the Aux tank tomorrow and see if that changes anything. I have never run this thing out of fuel before ( Since I converted to EFI ). Does this sound consistent with a fuel starvation problem?
Either way, we will be there.
Sat Oct 05, 2013 10:13 pm
32,992,434 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
