www.ColoradoClassicBroncos.com - View topic - Bronco number 3 - A four year project.
It is currently Wed Dec 11, 2024 3:11 pm
Reply to topic  [ 106 posts ]  Go to page Previous  1, 2, 3, 4  Next
Post Re: Bronco number 3 - A four year project.
A little more on intakes. Longer runners in the intake = More torque, correct? That would leave just a few options GT40 variations, Edelbrock performer, and Trick flow. Any others I'm missing? Didn't they used to sell adaptors that went between the head and intake so you could run a 5.0 intake on a 5.8? Its been a few years since I have seen them and Google is not helping so I guess no one makes them anymore or maybe they just didn't work that well. I have plenty of time to find what I need but I want to compile a list so I can jump on good deals as they come up.
Fri Sep 20, 2013 2:09 pm
Fri Sep 20, 2013 5:21 pm
Fri Sep 20, 2013 7:23 pm
BC broncos is the ones that make em and sell em.
Fri Sep 20, 2013 7:52 pm
Fri Sep 20, 2013 8:14 pm
Fri Sep 20, 2013 8:41 pm
this is what both of you need.
http://www.fordracingparts.com/parts/pa ... ield=23197
Fri Sep 20, 2013 8:46 pm
I'm sensing a tech weekend coming on! I'm in-- who has a multi bay garage with 3 engine lifts?
Fri Sep 20, 2013 9:27 pm
Fri Sep 20, 2013 9:56 pm
Fri Sep 20, 2013 10:02 pm
GT40 lowers are out there, some are even cheap, Zack spotted one under $300 a few months back.
Fri Sep 20, 2013 10:17 pm
Fri Sep 20, 2013 10:48 pm
Fri Sep 20, 2013 11:01 pm
Watch the Mustang forums. Wait for a deal, they come along.
http://forums.corral.net/forums/windsor-engine-parts/
Sat Sep 21, 2013 8:55 am
Sat Sep 21, 2013 10:43 am
Well, there won't be any going back now! With a lot of help from Kevin, I brought home a 96 5.8L from an F150. Kevin was nice enough to bring his work truck with a 10,000 lb crane so loading and unloading was a snap. Once it was home and on the engine stand, I put the boy on the pressure washer and let him get it cleaned up. Cleaning revealed that the engine was a Ford " Reconditioned" engine dated 2000. I'll pull the intake and heads tomorrow and see what it looks like.
Sat Sep 21, 2013 8:54 pm
This is what happens when you just go "Scouting"..
Glad I could help...
Sat Sep 21, 2013 9:09 pm
Nice score!
Sat Sep 21, 2013 9:37 pm
Sat Sep 21, 2013 10:15 pm
sounds like fun!
Sat Sep 21, 2013 10:37 pm
Anderson's sure does give up some nice stuff, great find.
Sat Sep 21, 2013 10:39 pm
Sun Sep 22, 2013 10:44 am
And the ARB compressor I pulled off that Bronco works just fine..
Sun Sep 22, 2013 2:56 pm
We broke it down and I was happy to see the dog bones on the lifters indicating that it had roller lifters, I was a bit concerned about what would be in there after we found it was a reman engine. How can I be sure if this thing has been bored or not? I believe that the pistons were marked 30 over on my other 351 but I don't see that on this engine. It all looks pretty good overall but it did have a surprise n the oil pan. I found a small bolt with a nut on it and a small hose clamp in there. How the hell does that happen? One of the photos is a bit dark but if you look close , you can see the bolt and clamp that was in the pan.
Sun Sep 22, 2013 5:18 pm
I went back to the junkyard today with Kevin in search of a set of GT40 heads. We found a set but ended up passing on them because of the engine condition. We pulled the intake and found 3/4" of oil sludge under it. We did pull the serpentine stuff to use on the boys Bronco but I the heads seemed like too much risk. I find Explorers often enough that I'll hold out for something better. I did at least score a set of #24 injectors from another vehicle.
Sun Sep 29, 2013 12:04 am
lightning lower, upper explorer, fuel rails, and more
Tue Oct 01, 2013 8:26 am
Does that bolt look like one that comes out of a carb and goes through an air cleaner to hold it on? Peter
Tue Oct 01, 2013 9:15 pm
Thu Oct 03, 2013 12:08 am
For some reason I can only get this photo to post using tapatalk. Strangeness.
Thu Oct 03, 2013 12:10 am
You can drop them off or I can bring all the goodies over there to get it out. Heat it up a little then spray the panther piss on it so it can soak into the threads.
Thu Oct 03, 2013 7:45 am
33,237,503 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
