new Emissions Laws!!!!
As of August of 2013 our wonderful communist government has put into effect a new law. ALL collector plated vehicles will be required to go through the 2 speed idle test now every 5 years when your collectors plates are due. So no more emissions exempt with a collector plated vehicle. Time to move from this crap hole Kolorado/californiaII End
Sun Oct 06, 2013 9:05 am |
Re: new Emissions Laws!!!!
I still haven't found that on the official CO Dept of Revenue website but it was on a secondary site. http://www.dmv.org/co-colorado/smog-che ... uirements- part way down the page it says: NOTE: While collector vehicles were previously exempt from emissions testing in the areas required, a law was passed into affect in August 2013 that now requires emissions inspections for vehicles registered as collector items. Please review the Collector Plate Regulations Change for more information.
Sun Oct 06, 2013 9:43 am |
Sun Oct 06, 2013 9:47 am |
My read on this is that the change only affects 1976 and newer vehicles.
"THE EXECUTIVE DIRECTOR SHALL ESTABLISH a biennial inspection schedule shall be established for 1982 and newer model vehicles, and an annual INSPECTION schedule shall be established for 1981 and older model vehicles, AND A FIVE-YEAR INSPECTION SCHEDULE FOR A 1976 OR NEWER MOTOR VEHICLE REGISTERED AS A COLLECTOR'S ITEM."
So, if you've got a 76-77 EB, then you'd have to have it tested every 5 years if it's registered as a collectors vehicle, otherwise it's yearly. That said, I'm a lousy attorney, so my read could be wrong.
Sun Oct 06, 2013 9:58 am |
Nope Justin that's the way I read it too.
Sun Oct 06, 2013 10:01 am |
Saw this one coming a mile back and was somewhat expecting it.
I hope I pass.
Sun Oct 06, 2013 10:52 am |
Geologist
_________________ 1966 Bronco, rebuilt 302, Twin shift Dana 20, T19, 3.5 suspension lift, 2 inch body, 35x12.50 tires
Sun Oct 06, 2013 11:23 am |
Looks like I'll keep my TX residency then... Unless we get to AK for the next duty station.
In reality, I remember having to have my '74 tested once in Denver and I was so worried it wouldn't pass as it smoked and ran poorly. But I didn't have any issues.
Mon Oct 07, 2013 5:43 am |
jre74
Check out this link: http://aircarecolorado.com/consumer-inf ... or-plates/I called the number listed at the bottom and spoke with one of the agents. 76 and newer registered as collector will now need an emissions test every 5 years (& on next renewal if you already had collectors plates on it). 75 and older is unchanged (won't need emissions) if you have collector plates. You will need to pass emissions once to get the collectors plates if you don't already have them. Hope this helps. Jeff
Mon Oct 07, 2013 8:36 am |
kbank6
So since I have a 73 and going with EFI, are they going to require me to have smog pumps etc since it is not the original 302??
Mon Oct 07, 2013 7:13 pm |
Is it registered as a collector vehicle already?
Sent from my DROID BIONIC using Tapatalk 4
Mon Oct 07, 2013 7:51 pm |
kbank6
No, I got it with Texas plates.
Mon Oct 07, 2013 7:59 pm |
Mon Oct 07, 2013 8:47 pm |
Its now a rolling 32 years if you meet the conditions listed.
Mon Oct 07, 2013 8:51 pm |
kbank6
The inconsistency is what I'm worried about but I guess I will just have to see.
Mon Oct 07, 2013 9:02 pm |
I'd get it past smog, then put collector plates on it. Then you'll be able to do whatever you want. Not sure that smog will be that big a deal for a '73.
Mon Oct 07, 2013 10:48 pm |
I don't have emissions testing here, now (yet?). After reading this thread, I'm thinking I should go ahead and get Collector's tags the next time mine expire. That way I wouldn't have to get tested if they start testing here in Gunnison.
Not sure what a 74 needs to pass, but I know I'm not running and EGR on my EFI, and my truck had an EGR on the original 2bbl manifold.
Mon Oct 07, 2013 11:49 pm |
When I had mine tested many years ago, they hooked up the exhaust sensor, popped the hood, ran the test, shut the hood and handed me my passing paperwork. No one said a thing about it being EFI or anything. It's kinda a gray area. If I were to pass the emissions for the year of the engine, I'd be in a world of hurt.
Tue Oct 08, 2013 12:23 am |
Landshark - As Justin said you could get it but it will need emission testing every 5 years when it comes to renewal. At least that's the way I read it as well.
To kbank6 - like Jesus_man said they won't care what you have as long as it passes the sniffer test. They just have to pop the hood to hook up to a plug wire for the tach. I know from previous experience that if your rig has too high of an idle speed they will fail it. Mine loads the torque converter pretty hard in drive so in order to get it to idle in drive the in park idle is about 1000 or a little more. Over 1000 I think it fails so it needs to idle under 1k. At least that's what I remember back 15 or so yrs ago.
Tue Oct 08, 2013 3:55 am |
Tue Oct 08, 2013 9:21 am |
You might be able to get Collector plates for it and avoid smog for several more years. The criteria are:
"(c) A MODEL YEAR AT LEAST THIRTY-TWO YEARS OLD; EXCEPT THAT, IF THE VEHICLE IS BEING REGISTERED IN THE PROGRAM AREA, AS DEFINED IN SECTION 42-4-304: (I) THE VEHICLE MUST HAVE PASSED AN EMISSIONS TEST MEETING THE STANDARDS OF PART 3 OF ARTICLE 4 OF THIS TITLE WITHIN THE LAST TWELVE MONTHS BEFORE BEING INITIALLY REGISTERED BY THE OWNER AS A COLLECTOR'S ITEM; AND (II) THE OWNER MUST SIGN AN AFFIDAVIT THAT THE VEHICLE WILL NOT BE DRIVEN ON ROADWAYS FOR MORE THAN FOUR THOUSAND FIVE HUNDRED MILES PER YEAR."
Not sure if you meet (or care about) the mileage criteria, but other than that you should be covered if you've still got your smog paperwork from last year.
Tue Oct 08, 2013 11:09 am |
plumbdoctor
Interesting??
Wed Oct 09, 2013 10:03 pm |
trei75bronco
Joined: Wed Jan 26, 2011 10:55 pm Posts: 837 Images: 0
I worked at air care Colorado the first three years it was in existence. It realky is a joke buy they have relaxed alot. When I was there if the engine was not original or if you put efi on a carb truck or car we automatic failed it. Then you would havget a notorized letter from a mechanic saying it was "ok" then fill out all kinds of forms to approve the new motor. . Pain in the ass There are still tail pipe only emission places around town go to them. There was one off Broadway for years. He was awesome Find the dumbest looking ing retard you can dont say anything about the motor or cats because I think they can make you jump through those hoops still
Thu Oct 10, 2013 8:40 am |
Sun Oct 20, 2013 6:27 am |
ok just went and got my emission testing done and renewed my registration on the 76 bronco.
I now have 5 year collectors plates as vehicles 1981 and older now qualify - cost me $199 which is well worth it.
In order to qualify for the 5 year plates you will need a emissions test done in the last year...
BTW had to go to a new independent emission inspection place as Jerrys on Wadsworth is no longer in business.. The new place I went to on Federal didn't ask me one question except for what year the Bronco was.
Thu Dec 26, 2013 2:12 pm |
Moab Mike
Good news! Would you post the name and address of the new place for us?
Thu Dec 26, 2013 2:41 pm |
Discount Auto Emissions 3700 Federal Blvd, Denver, CO 80211 (303)458-6809
I would call before heading over.. they are on the side street just a little one car garage place... tiny
Thu Dec 26, 2013 2:53 pm |
EFI Guy
Crap! I just renewed my plates today. If I would have known that my 81 could have gotten collector plates I would've got them.
While I don't believe it should ever have to visit the smog nazis, every 5 years sure beats every year.
Oh, just to brag a little....Not too bad considering it's got a Trickflow cam in it:
Thu Dec 26, 2013 8:58 pm |
Those numbers are great.
Thu Dec 26, 2013 9:34 pm |
Moab Mike
I just found this if you want to bypass Air Care Colorado.
Mon Jan 20, 2014 10:47 am |
