Register •
FAQ
• Login
It is currently Mon Nov 25, 2024 4:56 pm
[ 4 posts ] |
B.C. Broncos exhaust kit
So I took the gamble and recommended the B.C. Broncos 2 into 1 exhaust kit for my brother in laws Bronco. The kit states it is for stock engine, transmission and t-case only. My brother in law has an NP435 in his Bronco. I finished installing the exhaust today and I'm very happy with it. If fit perfectly and sealed up on the first shot. I ended up adding some pre bent pipe to extend the exhaust to the back of his Bronco as the kit only gives you a turn down. The turn down is my only gripe with the system as it doesn't fit the muffler. Not sure what happened but it was clearly meant to fit it. I wouldn't be surprised if Magnaflow changed the output size and didn't inform B.C. Broncos. Anyway, I just figured I'd post this in case anyone was on the fence about buying the kit. The engine is running so much better now, which is a very nice bonus.
Sat Dec 28, 2013 6:36 pm |
trei75bronco
Joined: Wed Jan 26, 2011 10:55 pm Posts: 837 Images: 0
Re: B.C. Broncos exhaust kit
I have bc 2 to 1 as well with wh headers and it added some great torque.. fit well with np435 as well
Sat Dec 28, 2013 11:10 pm |
B.O.B.
Same here. Had to do a little fiddling with mine because I used the huts headers, then went to house of mufflers and finished off the rest. Sounds awesome though and definitely improves some power.
Sun Dec 29, 2013 9:51 am |
plumbdoctor
Like the set up... Gonna run it on the polished turd as well
Sun Dec 29, 2013 1:31 pm |
[ 4 posts ] |
Users browsing this forum: No registered users and 89 guests |
