It is currently Mon Nov 25, 2024 4:27 pm
[ 12 posts ] |
Broncoguy73
Joined: Mon Feb 20, 2012 10:09 pm Posts: 126 Location: Highlands Ranch
Explorer cam
I'm going to the explorer EFI set up while still using my 72 block for now which means the wrong firing order. Slim chance but I figured I would see if any one had a cam from a late 90's explorer 5.0?
Sun Jan 05, 2014 8:43 pm |
Re: Explorer cam
Last edited by crawlercreations on Sun Jan 05, 2014 9:06 pm, edited 1 time in total.
Sun Jan 05, 2014 8:49 pm |
Broncoguy73
Re: Explorer cam
I need the roller block before if get the roller cam... Duh
Sun Jan 05, 2014 8:58 pm |
plumbdoctor
Re: Explorer cam
It will still run fine with the old order
Mon Jan 06, 2014 12:36 am |
Re: Explorer cam
I bet EFI Guy can reprogram the spark plug & injector firing order to match the cam. He can do it with the Mustang EFI. I'm running the Mustang EFI with my old cam and incorrect injector firing order, and it runs fine.
You might be able to use the Explorer cam, there are aftermarket "dog bone" retainers to fit roller lifters in an old block. I'm not 100% sure how its done, but I think it will work.
Mon Jan 06, 2014 9:17 am |
Re: Explorer cam
L
Mon Jan 06, 2014 9:36 am |
B.O.B.
Re: Explorer cam
I put a 351 cam in that is the right firing order. Wasn't to expensive.
Mon Jan 06, 2014 9:44 am |
Re: Explorer cam
Mon Jan 06, 2014 10:36 am |
Re: Explorer cam
Mon Jan 06, 2014 10:47 am |
Broncoguy73
Re: Explorer cam
Im just going to roll with what i have since everyone says it will run fine. Down the road ill do the full swap with a explorer motor plus the 4r70w
Mon Jan 06, 2014 1:14 pm |
EFI Guy
Re: Explorer cam
Mon Jan 06, 2014 6:06 pm |
Broncoguy73
Re: Explorer cam
You are the man!
Mon Jan 06, 2014 6:12 pm |
[ 12 posts ] |
Users browsing this forum: No registered users and 122 guests |
