www.ColoradoClassicBroncos.com - View topic - Cooler?
It is currently Mon Nov 25, 2024 5:47 pm
Reply to topic  [ 13 posts ]
 Cooler?
Post Cooler?
I'm looking to redneck engineer an aftercooler for my newly replaced air compressor. I need something like a transmission cooler that will handle 150 psi reliably and is a square foot or two. Ideally, it'd have 3/8 or 1/2" connectors on it. Something like this:
http://www.summitracing.com/parts/flx-45321
would be perfect, but I don't want to spend $125. Any ideas?
Wed Jan 22, 2014 2:27 pm
Post Re: Cooler?
Transmission cooler circuits are typically low pressure, less than 50 psi. Don't know if a trans cooler would be reliable at 150 psi. You could always pull one from a wrecking yard and test it's burst pressure.
Wed Jan 22, 2014 5:19 pm
Post Re: Cooler?
You might look at AC condensers it can handle the pressures and old R12 units have larger fitting.
Wed Jan 22, 2014 7:18 pm
Profile WWW
Post Re: Cooler?
Some of the aftermarket trans coolers are advertised as tested to 200 psi, but I share the concern about using one. Horse, I'll look into that. Might be a good option.
Wed Jan 22, 2014 7:58 pm
Post Re: Cooler?
Run your line through a tray of water?
Thu Jan 23, 2014 3:48 am
Post Re: Cooler?
Thought about that, but don't want to maintain it.
Thu Jan 23, 2014 9:58 am
Post Re: Cooler?
Convert your line to copper, buy a small copper coil, drop that into the 5-gal bucket with a lid and cut holes in the lid as necessary and hang the bucket from the ceiling or something. Maintenance would only be re-filling and possibly draining in the winter? Trouble would be getting a larger size tube to coil that tight and supply the needed volume. So maybe a galvanized tub would be better. Then it becomes cumbersome. Ok, I've pretty much talked myself out of that idea.
Liquid Nitrogen?
Thu Jan 23, 2014 10:07 am
Post Re: Cooler?
Liquid nitrogen would be awesome! Aftercooler and home cryo in one! The other issue with the water/coil method is that there isn't any way to easily get the condensation out of the lines. With an air cooler I can mount it above the compressor and let gravity drain the water into a water trap.
Thu Jan 23, 2014 12:03 pm
Post Re: Cooler?
You don't need a compressor. You need a big CO2 tank.
Thu Jan 23, 2014 12:16 pm
Post Re: Cooler?
Why do you want to cool the air? Spraying ?
Thu Jan 23, 2014 7:38 pm
Post Re: Cooler?
Spraying is part of it. Cooler, drier air will also make a difference for my plasma consumables. People are seeing a 100-150 degree difference in the temp of the air entering the tank, and collecting a noticeable amount of water out of the system. It also means that slightly more air can be held in the tank since cooler air is more dense.
Thu Jan 23, 2014 8:11 pm
Post Re: Cooler?
Ok, I was just wondering. I know that keeping water out of the lines is important, just hadn't heard about cooling the air. You must be running the compressor continuously creating heat build up from the pump, maks sense.
Thu Jan 23, 2014 8:18 pm
Post Re: Cooler?
Been doing some more reading. It looks like the Derale coolers are rated to 300psi, but my best bet may be a AC condenser. Anyone have a spare laying around? In a perfect world it'd have 3/8" or 1/2" connections, but I can braze different ones on if needed. Automotive is good, but I'm equally happy to take apart your broken refrigerator or AC unit.
Sun Jan 26, 2014 10:44 pm
Users browsing this forum: No registered users and 143 guests
33,081,202 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
