www.ColoradoClassicBroncos.com - View topic - Hood Shocks Install
It is currently Mon Nov 25, 2024 7:44 am
Reply to topic  [ 20 posts ]
 Hood Shocks Install
Post Hood Shocks Install
Who's installed the WH hood shocks and are there any nuances I should know about (OEM hood).
http://www.wildhorses4x4.com/product/Hood_Shocks
Wed Jan 29, 2014 1:54 pm
Post Re: Hood Shocks Install
I've had them for about a year but still haven't gotten to installing them. If I can get my spare hoods to the house from
Penrose this weekend I'll get them installed and let you know.
Wed Jan 29, 2014 3:19 pm
Thanks. I'm going to install mine this weekend so I'll post up how it goes.
I have the similer product from Jeffs for my fiberglass hood and love em.
Owned my 1972 since 1985
Canon City, Co
Wed Jan 29, 2014 4:09 pm
Yea...I'm concerned they won't fit on mine. My MAF filter and tube is right where the shock would collapse into.
http://cdn.wildhorses4x4.com/downloads/ ... 7-08_1.pdf
Wed Jan 29, 2014 4:13 pm
Wed Jan 29, 2014 4:59 pm
You're first in line:)
Wed Jan 29, 2014 5:04 pm
You should be fine. They hug pretty close to the fender.
Wed Jan 29, 2014 8:17 pm
That's the problem...my filter butts up against the fender. Might have to relocate it a bit.
Wed Jan 29, 2014 9:09 pm
My complaint with the WH and others is they use a strut with inadequate force and they have very short life. I now am using some ebay versions that had double the force. So far they are still working and the hoot jumps right up. Now Autozone sells replacement struts so its easier to replace them.
PaulW
Thu Jan 30, 2014 9:36 am
Do you have a link to the ones you bought on eBay?
Thu Jan 30, 2014 9:39 am
I would also look at the longer mounts on the hood. The shorter ones tend to make the hood fold. I think duff carries them
Thu Jan 30, 2014 12:52 pm
I'm planning to go with these.
As Landshark says, the brackets are much better.
http://www.dufftuff.com/Hood_Struts_196 ... p/4950.htm
Thu Jan 30, 2014 4:06 pm
Sat Feb 01, 2014 11:56 am
Sat Feb 01, 2014 11:59 am
They are installed:) But only after...
1. Removing and re-positioning the set of EFI relays and fuses.
2. Calling WH to get clarification on instructions.
3. Stripping one of the sheet metal screws and going to Ace for a new one, that didn't work, so I used a bolt.
4. Finding my stubby power drill because the hydroboost was in the way of drilling holes.
All in all it wasn't that bad. And the shocks are MORE than enough....no need to get stronger ones. The hood flies up after you get it about 1/4 of the way. Very nice upgrade.
Mon Feb 03, 2014 7:37 pm
Nicely Done !
Looks like you have even better engine access as the hood is higher than stock "open" position ?
Mon Feb 03, 2014 7:40 pm
Yep...noticed I have to reach up a bit higher to grab it.
Mon Feb 03, 2014 8:04 pm
Heck, that alone makes it a worthwhile install.
Mon Feb 03, 2014 8:06 pm
Tue Feb 04, 2014 3:28 am
Users browsing this forum: Google [Bot] and 29 guests
33,032,335 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
