www.ColoradoClassicBroncos.com - View topic - Dash bezel removal
It is currently Mon Nov 25, 2024 7:49 am
Reply to topic  [ 7 posts ]
 Dash bezel removal
Post Dash bezel removal
I know that the ignition has a trick with a paper clip but how do the rest of the bezels come off? Does anyone have a bezel removal tool I could borrow? They all seem different behind the dash... Are there different ways to pull everything off?
Sun Feb 02, 2014 2:56 pm
Post Re: Dash bezel removal
For the ignition, pull the lock using the paper clip and then it you push from behind and twist to get it out. I used a small punch to tap the others loose. Some come out of the dash toward the interior and others toward the firewall. For the the ones that go in you can remove the pull by loosening the set screw with a small allen wrench. The tool would definately help but you can do without if you are careful.
Sun Feb 02, 2014 3:11 pm
I've got the bezel removal tool. It makes removing the bezels without damage about 1,264% easier. You're more than welcome to borrow it.
Sun Feb 02, 2014 6:24 pm
Sun Feb 02, 2014 6:47 pm
I made one out of a deep 7/16" socket.
Sun Feb 02, 2014 7:09 pm
Justin is about 15 minutes away. Thanks for the offers.
Sun Feb 02, 2014 9:44 pm
Let me know when you want to swing by. I should be in the garage tomorrow evening if work doesn't suck.
Mon Feb 03, 2014 12:46 am
Users browsing this forum: No registered users and 24 guests
33,032,462 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
