www.ColoradoClassicBroncos.com - View topic - No power anywhere!!!!!!
It is currently Mon Nov 25, 2024 7:27 am
Reply to topic  [ 11 posts ]
Post No power anywhere!!!!!!
I am in the final assembly of the 72 restoration and have everything wired up and I have no power anywhere. Ignition key does not work no lights ect.... I have checked and replaced all fuses hew voltage regulator, tried a few different ones as well. I'm sure I'm missing something stupid. Any ideas? I was going to activate the viper wolf signal to help but lost all contacts in my phone. I really need to get this beast fired up soon and on the road. Beers to anyone that can help out with advice or a donation of time.
What did you learn?
Mon Feb 03, 2014 8:05 pm
Post Re: No power anywhere!!!!!!
Good voltage at the battery? Good voltage on the side of the starter relay that the battery runs to?
Mon Feb 03, 2014 8:14 pm
The motor cranks when the solenoid is bypassed. No power after the solenoid but that is new as well.
What did you learn?
Mon Feb 03, 2014 8:18 pm
This is on a 72 as well. From left to right.
Key off
1: 12v
2: 0v
3: 0v
4: 0v
Key in run position
1: 12v
2: 0.05v
3: 12v
4: 0v
I pulled those number 5 minutes ago.
Seeing something similar?
Mon Feb 03, 2014 8:44 pm
Looks identical.
What did you learn?
Mon Feb 03, 2014 8:48 pm
Have you got a multimeter to test those numbers?
Mon Feb 03, 2014 8:52 pm
1 -12. Key on and off
2 -0.
3 -0.
4 -0.
What did you learn?
Mon Feb 03, 2014 9:36 pm
Fusible link
Mon Feb 03, 2014 9:39 pm
Mon Feb 03, 2014 10:34 pm
It appears my wire is blue. I'll check it's connections in the morning. Thanks for the help
What did you learn?
Tue Feb 04, 2014 8:58 pm
You can check for voltage at both ends and then pierce the insulation just before/after the fuse to verify. Junkyards are full of "spares" for little to nothing. smokin
Tue Feb 04, 2014 9:48 pm
Users browsing this forum: No registered users and 19 guests
33,031,837 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
