It is currently Sat Nov 23, 2024 5:11 pm
[ 11 posts ] |
How many PMs is too many?
Over the last year or so I have bumped up the maximum number of PMs you can have stored in your inbox. Currently, every user can have 200 in each folder.
My question is, does anyone out there find they need more than that or am I the only one guilty of hoarding both Bronco parts and Bronco messages?
Fri Mar 28, 2014 8:20 pm |
Re: How many PMs is too many?
Every couple months I have to weed out the old ones.
Fri Mar 28, 2014 8:27 pm |
I had to clean out my message folders the other day when I maxed out my Inbox. Used to happen all the time when it was set for 100. But most of it was really old.
Fri Mar 28, 2014 8:36 pm |
200 lasts me 4-6 months.
Fri Mar 28, 2014 8:51 pm |
The new max is great, I use to have to clean up all the time, you're enabling my inner lazy.
Fri Mar 28, 2014 9:51 pm |
casadejohnson
Fri Mar 28, 2014 10:05 pm |
Fri Mar 28, 2014 10:11 pm |
Fri Mar 28, 2014 11:52 pm |
I'm good with the current limits.
Mon Mar 31, 2014 2:12 am |
200 is good here as well.
Tue Apr 01, 2014 10:51 am |
I guess I just not that popular. I have never cleared mine.
Tue Apr 01, 2014 6:54 pm |
[ 11 posts ] |
