www.ColoradoClassicBroncos.com - View topic - My 76' Work in Progress
It is currently Thu Nov 21, 2024 11:04 am
Reply to topic  [ 80 posts ]  Go to page Previous  1, 2, 3  Next
Post Re: My 76' Work in Progress
I failed to mention earlier that Landshark was an integral part of the install crew. My humble apologies for my omission.
Here are some pics as promised!
Tue Apr 15, 2014 9:09 pm
More pics................
Tue Apr 15, 2014 9:10 pm
I also found I made a grave error with the placement of the drivers side O2 sensor. It sits above the front drive shaft about 3/8" which means it would be taken out on the first bump. The remedy is to pull the header, cut out the O2 bung and patch it then re-drill and re-weld it back in. It appears it will cost me another day I don't have.
Tue Apr 15, 2014 9:20 pm
Mike you are really making great progress.
I got the beer on ice !
Tue Apr 15, 2014 9:21 pm
Items remaining:
Cold air intake
Install throttle cable
Install kick down cable
Correct the serpentine belt
Wire the fuel pump and sending unit
Wire the OBD II (5 Wires)
Ground the battery and add positive wire to the alternator
Time the Cam Position Sensor
Install the Coil Pack
Install the plug wires
Pull the drivers side header and correct my f**K up
Tighten cross member bolt and transmission shift rod
Install the drive shafts
Add gasoline
Install exhaust
Install the hood
Tue Apr 15, 2014 9:33 pm
Why long tube headers instead of shorties?
Tue Apr 15, 2014 9:48 pm
Add route serp belt correctly.
Tue Apr 15, 2014 9:50 pm
Tue Apr 15, 2014 9:51 pm
use a pipe plug on the exhaust pipe, cut a new hole and don't pull the pipe... thats what they did on my exhaust.. not leaks so I would assume it would be ok?
Tue Apr 15, 2014 10:13 pm
Was going to say the same thing as Landshark - saves time, money, headache, and back on track.
Tue Apr 15, 2014 10:45 pm
Great progress. Glad to see someone else crazy enough to take on a huge undertaking right before Moab!
Tue Apr 15, 2014 11:28 pm
Looking good! Especially the dude wearing the V8 hat.
I also looked at the serp set-up and thought something didnt look right compared to mine but since "It's just your truck" I let it go. Here's the common pic I use minus the AC.
http://www.google.com/search?q=v8+explo ... B576%3B432
I'm so happy that this is your truck....and not mine!
Wed Apr 16, 2014 12:08 pm
Looking great! You're making good progress.
Why do ya have to re-wire the OBD2 port? Did you need to cut it or de-pin it it to get it through the firewall?
Thu Apr 17, 2014 10:32 pm
Fri Apr 18, 2014 5:45 am
I hope to fire it up tonight.
Items remaining:
Add gasoline
Install exhaust
Install the hood
Cold air intake - DONE
Correct the serpentine belt -DONE
Pull the drivers side header and correct my f**K up - DONE (Thanks Landshark)
Tighten cross member bolt and transmission shift rod - DONE
Install the drive shafts - DONE
Fri Apr 18, 2014 5:54 am
*fingers crossed!*
Fri Apr 18, 2014 6:12 am
Fire it up tonight? So we should see you at breakfast tomorrow then. :)
Fri Apr 18, 2014 7:15 am
Fri Apr 18, 2014 7:49 am
Got the new engine fired up tonight. I need to work out some bugs. My JY fuel pump is barely putting out enough pressure to keep it at idle. When it does have enough fuel pressure it sounds great! I have to clean up the wiring and get the exhaust but it is getting there.
A special thanks to both EFI Guy and Viperwolf1 for their tech support!
Mon Apr 21, 2014 8:51 pm
Congrats, I know you feel great!
Mon Apr 21, 2014 8:55 pm
That is awesome !
Moab here we come !
Mon Apr 21, 2014 8:56 pm
nice job mike
Mon Apr 21, 2014 8:57 pm
Nice. Looking forward to actually running some trails with you! stirpot
Mon Apr 21, 2014 8:58 pm
WOOOOOOO HOOOOOOOOOOOOOO! My Bronco sense was tingling just about that time. But it was just gas. I've got another JY pump if you want to give it a go. I hope it's not a bad filter or the crap I put in the fuel lines.
Mon Apr 21, 2014 9:47 pm
I heard it from here!! Now I am looking forward to the convoy of Bronco's West Bound and Down!!
Tue Apr 22, 2014 5:56 am
Sweet!
Tue Apr 22, 2014 7:19 pm
Any updates?
Thu Apr 24, 2014 10:15 pm
Nice Job Mike! I like how you mounted your computer too. Thats how I want to mount mine as well.
Fri Apr 25, 2014 6:39 am
Fri Apr 25, 2014 9:10 am
32,916,944 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
