It is currently Mon Nov 25, 2024 1:51 pm
Can we do it ?
I love my 5.0 EFI but am getting the itch to "go big".
I am thinking about a 351 EFI with Explorer OBDII harness.
Sounds easy enough....................but I don't want a body lift and I want to retain the stock hood.
I thought I read about someone on CB.com having pulled this off but I can't find the thread.
Or, should I just freak out and go Coyote ?
Wed May 21, 2014 8:25 am |
Re: Can we do it ?
Duh, go Coyote!
Wed May 21, 2014 8:32 am |
Re: Can we do it ?
coyote!!!!! go test drive a mustang or f150.
Wed May 21, 2014 8:39 am |
D&D72
Re: Can we do it ?
What they Said! ^ all it takes is money......
Wed May 21, 2014 8:44 am |
Re: Can we do it ?
You're gonna need a body lift.
Wed May 21, 2014 9:19 am |
Dukietown
Re: Can we do it ?
I'd be interested in your Explorer motor if you end up going the way of the 351.
Wed May 21, 2014 10:39 am |
Re: Can we do it ?
Coyote!!!
Wed May 21, 2014 11:20 am |
Re: Can we do it ?
Did you think you'd get any answer besides coyote?
Wed May 21, 2014 11:26 am |
Moab Mike
Re: Can we do it ?
MORE TORQUE!!! 4BT!!!!!! But if you really want to haul a$$, Put a blower on top of the Coyote. No body lift needed but you will need to cut the hood.
Wed May 21, 2014 11:37 am |
Re: Can we do it ?
yotes LOVE boost. They react very well.
Wed May 21, 2014 12:21 pm |
Re: Can we do it ?
My vote is 351W. But that's the practical side of me thinking about sitting in the middle of Nowhere, USA waiting for my Coyote motor parts to arrive in 3-7 days.
Wed May 21, 2014 12:26 pm |
sbolt19
Re: Can we do it ?
Doesn't BC make an adapter plate for the 351 manifold to a 5.0 plenum that makes it so you don't have to put a body lift on? Or is the 351 a taller engine overall?
Wed May 21, 2014 2:13 pm |
Re: Can we do it ?
Deck height is 1.3" taller. Mine sure sits tall in the engine compartment, but PO also installed extreme motor mounts.
Wed May 21, 2014 3:22 pm |
EFI Guy
Re: Can we do it ?
I vote V-10, with a K/B or Whipple huffer.
Wed May 21, 2014 8:13 pm |
Re: Can we do it ?
The BC adapter is for using a stock 5.8 lower manifold from a truck with a stock 5.0 upper manifold from a mustang or explorer.
Wed May 21, 2014 8:18 pm |
Re: Can we do it ?
I wouldn't change a thing - your engine and Bronco build turned out amazing.
Wed May 21, 2014 11:26 pm |
Gregg
Re: Can we do it ?
Thu May 22, 2014 12:34 pm |
Re: Can we do it ?
351w roller mild build efi would be my vote. But you might be going with an after market hood :)
Thu May 22, 2014 1:53 pm |
Re: Can we do it ?
351w has great torque down low, Bubba Smurf's motor is from 1969 & original and it still has great torque. I have no experience with the coyote motor besides YouTube videos.
Thu May 22, 2014 5:18 pm |
Colorado75bronc
Re: Can we do it ?
I think if you're going to the effort of doing this all over again you should just bite the bullet and do a coyote and a 6R80 that's what I plan to put in a LUBR when I finish my current bronco
Thu May 22, 2014 6:45 pm |
Re: Can we do it ?
Thu May 22, 2014 6:50 pm |
cpldavis37
Re: Can we do it ?
For the 10-15000 you will spend with a coyote swap I bet you could have a 351 stroker built to the hilt. The accessories will stay the same, computer ect... and the most important thing is mechanical support. It comes down to cost vs gain. On the other hand it is a cool factor thing.
Thu May 22, 2014 8:29 pm |
Re: Can we do it ?
I've never seen a Bronco with a wankel engine.
Thu May 22, 2014 9:01 pm |
Re: Can we do it ?
You said Wankel.
Thu May 22, 2014 9:19 pm |
Re: Can we do it ?
This will be showing up at my door step soon. Score of the century, new old stock Lightening intake.
Sun May 25, 2014 9:30 am |
Re: Can we do it ?
Wow. NOS, awesome.
Sun May 25, 2014 9:46 am |
Re: Can we do it ?
You're going to have to pass that off to Bubba Smurf, that thing won't fit a Coyote!
Sun May 25, 2014 2:19 pm |
Re: Can we do it ?
Sun May 25, 2014 2:28 pm |
kbank6
Re: Can we do it ?
I have the same one and will do the bigger baffle plate soon.
Mon May 26, 2014 7:26 pm |
EFI Guy
Re: Can we do it ?
Sweet! I was hoping you would score it being #2 in line.
Mon May 26, 2014 11:58 pm |
Users browsing this forum: No registered users and 104 guests |
