It is currently Sun Nov 24, 2024 6:04 pm
Re: 7.3L diesel advice
Mon Jun 09, 2014 7:43 pm |
Mon Jun 09, 2014 7:47 pm |
casadejohnson
Mon Jun 09, 2014 10:53 pm |
Because the Riff Raff wheel is CNC'd from billet aluminum where the wicked wheel is likely cast.
Tue Jun 10, 2014 12:33 am |
Tue Jun 10, 2014 2:56 am |
Tue Jun 10, 2014 5:43 am |
casadejohnson
Sooo. If Im going to tear into the turbo, the riff raft wheel is the way to go. For my intercooler, either I bite the bullet on the early 99 parts or go aftermarket. Up pipes from Riff Raff and down pipe from? I keep hearing about Diamond Eye for that. How big of down pipe can get wedged into the OBS? I think you need to use a BFH to get anything bigger than stock in there. Damn You IH 7.3 !! I still have post Moab Bronco repairs to make!
Tue Jun 10, 2014 7:29 am |
How does the Riff Raff wheel compare to WW2?
Tue Jun 10, 2014 7:55 am |
The billet wheel made a huge difference over the ww. with the ww in my 100hp tune I could only see a max of 22psi. Now I see 28-29 with spikes to 32-33 on shifts. EGT's went down by 150* or so.
Jeremy, from what I hear on the OBS trucks you can only go as big as 3" down pipe without beating the crap out of the firewall. I have MBRP and it is nice n quiet with zero drone which is what I wanted. I've heard good things about diamond eye too.
Tue Jun 10, 2014 8:40 am |
Tue Jun 10, 2014 8:52 am |
Tue Jun 10, 2014 8:55 am |
Tue Jun 10, 2014 10:27 am |
Tue Jun 10, 2014 12:25 pm |
I never had surge issues until I put on a 4" down pipe. And that was pre tunes. A ww is a step backwards for flow/performance on post 99 trucks.
Tue Jun 10, 2014 12:34 pm |
Cool, good to know.
Tue Jun 10, 2014 12:51 pm |
I would recommend doing a billet wheel if you have to pull the turbo for any reason. I see it as a well worth it upgrade.
Tue Jun 10, 2014 12:59 pm |
casadejohnson
Tue Jun 10, 2014 9:42 pm |
There are lots of different plumbing configurations on those engines. I see them everyday in the FedEx trucks.
Tue Jun 10, 2014 10:01 pm |
casadejohnson
Wed Jun 11, 2014 12:14 am |
Wed Jun 11, 2014 2:45 am |
kbank6
I still had to use a BFH for the 3" down pipe I used in my OBS. I'll also come over and drink some beer while you get that installed.
Wed Jun 11, 2014 8:29 pm |
casadejohnson
Wed Jun 11, 2014 11:28 pm |
Thu Jun 12, 2014 1:09 am |
casadejohnson
I spotted a freshly rebuilt international in our mechanics shop this evening. I tried to slip it out the back door but they started giving me the stink eye. Sent from my iPhone using Tapatalk
Fri Jun 13, 2014 8:48 pm |
kbank6
I can sneak in with the crane if you distract him wih a delivey.
Sat Jun 14, 2014 5:52 am |
casadejohnson
So, it had been a little while since we had made the traditional saturday junkyard run so today we made the trip without plans to find anything in particular. Todays run yielded not one but two 7.3L power strokes ! I have never seen anything but an IDI diesel in the yard up here before. Anyway, Look what followed me home. I think I have everything needed to put an intercooler in my truck and the best part is that I got it all for $66! I even got the oil cooler since mine has a little leak.
Sat Jun 14, 2014 9:34 pm |
EFI Guy
That's a helluva score!
Sun Jun 15, 2014 12:06 am |
casadejohnson
Sun Jun 15, 2014 9:10 am |
6.0 coolers are known to be a fair bit more efficient. I was shocked when I saw my first one too with the plastic ends, but it did help the EGT's over the stocker.
Sun Jun 15, 2014 12:55 pm |
Im interested in the 6.0 IC
Sun Jun 15, 2014 7:25 pm |
