www.ColoradoClassicBroncos.com - View topic - Hydraulic clutch
It is currently Mon Nov 25, 2024 12:52 pm
Reply to topic  [ 10 posts ]
 Hydraulic clutch
Post Hydraulic clutch
I'm thinking of converting to a hydraulic clutch to free up some room on the drivers side for exhaust routing. I've also got dreams of someday dropping in a 5 speed trans. Are there any other benefits and what does it take to make it happen? I'm running a NP435.
Sat Jul 05, 2014 1:18 pm
Post Re: Hydraulic clutch
I wonder if a BB setup from a zf5 could be easily adapted to work?
Sat Jul 05, 2014 2:51 pm
Yeah, if at all possible, go with an external slave. No one wants to pull the tranny to swap out the slave.
Tue Jul 08, 2014 6:53 am
This is off of a Bronco Facebook post, reported here without verification. If true this would be an easy way for older standard transmissions that have detachable bell housings to upgrade to a hydraulic setup. Try it out Justin and let us know if it works.
You can source an E4TA small block bell housing from an 84 to 86 F series or Bronco they are set up for an external hydraulic slave cylinder and has the standard ford transmission bolt pattern.
Tue Jul 08, 2014 7:57 am
Thats cool!
Justin, you need to try that.
Tue Jul 08, 2014 11:26 am
Justin the external clutch from a big block (460) should work. You will have to figure out (build) a bracket but shouldn't be too tough.
Or go the bellhousing route ;)
It's nice to get rid of that crap on the frame.
Fabbing a bracket might work. If the trans/bellhousing is coming off, a ZF5 is going on.
Tue Jul 08, 2014 3:26 pm
Tue Jul 08, 2014 4:30 pm
Bring it on by! I'd love to get a look.
Tue Jul 08, 2014 4:53 pm
Tue Jul 08, 2014 4:59 pm
Users browsing this forum: No registered users and 68 guests
33,044,932 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
