It is currently Thu Nov 21, 2024 2:01 pm
The Evans clan has a new toy and member!
ol'glory82
Joined: Fri Jul 04, 2014 3:12 pm Posts: 11 Location: Hockeydads house
Well I can finally participate as an actual CCB member with the purchase of my own bronco over the weekend!! So far I have a shell temporary tranny, frame and a decent cage! It's a year unknown but as far as we can tell it's a 66-69. The goal is a good weekend driver with strong off-road capabilities! I am going full width axels, fuel injected 5.0l, or cobra motor, or lighting 5.4l but for the time being it will likely get a 302. For now it has a 3 speed on the floor but I intend on going 5 speed with it. Other than that it's an open book! The goal is to have it running and driving in the next couple months.
Mon Jul 07, 2014 7:10 pm |
Re: The Evans clan has a new toy and member!
99 Explorer with transmission, barely touched, just waiting for at the COS UPull. :D
Mon Jul 07, 2014 8:22 pm |
ol'glory82
Do you happen to know how much they charge there?
Mon Jul 07, 2014 8:52 pm |
About 200 for a complete motor.
Mon Jul 07, 2014 9:20 pm |
That's pretty good. Does it include Al the accessories and brackets?
Mon Jul 07, 2014 9:51 pm |
ol'glory82
Hmmmmmmm I like that! Auto tranny?
Mon Jul 07, 2014 9:56 pm |
Mon Jul 07, 2014 10:25 pm |
Mon Jul 07, 2014 10:26 pm |
EFI Guy
Probably just depends on who is working. But I suspect you could get it out the door with all of the brackets, now the alternator and P/S pump I can pretty much guarantee they'd charge you for.
Mon Jul 07, 2014 11:16 pm |
Tue Jul 08, 2014 6:31 am |
Congrats Dan on the new rig, it will be great to see it come together.
Tue Jul 08, 2014 6:32 am |
Indeed. Nothing makes me happier that witnessing the birth of a new Bronco addict. And it was only a matter of time before it spread in this family.
Tue Jul 08, 2014 6:37 am |
Tue Jul 08, 2014 6:39 am |
ol'glory82
Thank you everyone! And I'll probably head out to just stare at it tomorrow! Gotta get the little bros outta the garage so I can start mine! Ha and what kinda gearing are we talkin bout rox_crusher? I'll see if I can find the vin while I'm out there
Tue Jul 08, 2014 10:04 pm |
Where to find the VIN# [
Wed Jul 09, 2014 12:24 pm |
Passenger side frame rail, 16" behind motor mount.
Wed Jul 09, 2014 12:28 pm |
[quote="what kinda gearing are we talkin bout rox_crusher?[/quote] Dan, correct gearing is determined by how you intend to use the rig, factoring in how it is currently configured, or will be configured according to your mast plan. For me, I use mine as a week end warrior..........driving it at hiway speeds to get to the trail........and then mild / adventure level trails. So I picked the 4R70W electronically controlled OD transmission for hiway manners and low ratio of the 1st gear. This set up didn't shine with my 3:54 gears and 33" tires so I switched gears to 4:88. To me it is perfect. To somebody else it might not meet their use or they may have smaller / bigger tires to consider. Fool around with this a bit and you will be able to predict the best match up for your intended use. http://www.grimmjeeper.com/gears.html
Wed Jul 09, 2014 1:05 pm |
ol'glory82
That's one way to do it! Freightliner with a crane
Tue Jul 22, 2014 9:17 pm |
Might want to tell folks what you did with that crane son.....
Tue Jul 22, 2014 9:21 pm |
That roof looks crooked. Does this mean I might be rolling on 35s soon?
Tue Jul 22, 2014 10:08 pm |
ol'glory82
I used it to swap the rear axel, we used the crane to lift the bronco up ha and I believe they are bad tires, both the fronts were flat when I was out there Saturday! And yeah that top is crushed
Tue Jul 22, 2014 10:20 pm |
Pretty sure that 205 in the garage will bolt right up to that new ZF.
Thu Jul 24, 2014 4:40 pm |
ol'glory82
Well I'll be picking the motor and tranny up in the springs this weekend haha
Thu Jul 24, 2014 4:52 pm |
Thu Jul 24, 2014 4:55 pm |
ol'glory82
I'll buy my own Kirk!!!
Thu Jul 24, 2014 5:00 pm |
Thu Jul 24, 2014 8:31 pm |
Thu Jul 24, 2014 9:40 pm |
The parts gathering continues... Dan paid $350 for a complete 351 and ZF 5 speed both out of a 93 f250 4x4 Engine may be seized but we will hold off judgement until we get it on the stand and start to tear it down. Regardless, the plan is to rebuild both.
Sun Jul 27, 2014 9:09 pm |
Any chance that was a late 93 truck with an F4TE casting number?
Sun Jul 27, 2014 9:40 pm |
Don't know yet. Why? Is that a good thing?
Sun Jul 27, 2014 10:17 pm |
