www.ColoradoClassicBroncos.com - View topic - Just venting
It is currently Mon Nov 25, 2024 12:46 pm
Reply to topic  [ 6 posts ]
 Just venting
Post Just venting
Hopped In the old truck today to go to work, turn the key, noticed the fuel pump didn't prime. No fuel pressure, no start. Uugghhh. Guess I better start checking everything.
Wed Jul 09, 2014 7:52 pm
Post Re: Just venting
Maybe you'll get lucky and find a popped fuse, loose wire, etc.
Wed Jul 09, 2014 8:34 pm
Fuses are fine. Checked voltage at the wire going. Into the tank for the pump and that's fine. Only other tho g to
Do is to drop the tank and check inside. What a pain in the ass that's going to be with ten gal. Of fuel.
Wed Jul 09, 2014 8:53 pm
You can check the ground from the pump.
Wed Jul 09, 2014 9:43 pm
Or the relay.
Thu Jul 10, 2014 6:31 am
Swapped out the relays with the others. Same thing.
Thu Jul 10, 2014 1:15 pm
Users browsing this forum: No registered users and 74 guests
33,044,299 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
