It is currently Mon Nov 25, 2024 12:25 pm
[ 6 posts ] |
B.O.B.
Just venting
Hopped In the old truck today to go to work, turn the key, noticed the fuel pump didn't prime. No fuel pressure, no start. Uugghhh. Guess I better start checking everything.
Wed Jul 09, 2014 7:52 pm |
Re: Just venting
Maybe you'll get lucky and find a popped fuse, loose wire, etc.
Wed Jul 09, 2014 8:34 pm |
B.O.B.
Re: Just venting
Fuses are fine. Checked voltage at the wire going. Into the tank for the pump and that's fine. Only other tho g to Do is to drop the tank and check inside. What a pain in the ass that's going to be with ten gal. Of fuel.
Wed Jul 09, 2014 8:53 pm |
Re: Just venting
You can check the ground from the pump.
Wed Jul 09, 2014 9:43 pm |
Re: Just venting
Or the relay.
Thu Jul 10, 2014 6:31 am |
B.O.B.
Re: Just venting
Swapped out the relays with the others. Same thing.
Thu Jul 10, 2014 1:15 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 44 guests |
