It is currently Fri Nov 22, 2024 5:21 pm
Re: 351 collar
Sun Jul 20, 2014 8:08 pm |
D&D72
Re: 351 collar
Sun Jul 20, 2014 8:45 pm |
Re: 351 collar
Tue Jul 22, 2014 8:17 pm |
Re: 351 collar
Has anyone else installed one of these yet? How did you put the retaining bolt in to keep the synchronizer put? Also- with collar- only about 1/4inch of the oil pump shaft is engaged. EFIGuy gave me a part number for a longer shaft. I wasn't aware the shaft needed replacing so keep that in mind for anyone planning to do this in the future.
Wed Oct 08, 2014 5:25 pm |
Moab Mike
Re: 351 collar
That will need to be clocked correctly. The 5.0 is clocked parallel to the centerline of the engine. It also requires a special tool to hold the sensor in place when your installing it.
Wed Oct 08, 2014 5:44 pm |
Re: 351 collar
That pink stuff wipes off (unless your trying to steal shawntell's motif)
Wed Oct 08, 2014 5:53 pm |
EFI Guy
Re: 351 collar
I've got ya covered on the tool to clock it correctly.
For the hold down ya gotta be creative. I've seen a longer bolt with washers welded together and ground for clearance, or two hold downs welded together like this:
Wed Oct 08, 2014 6:10 pm |
Re: 351 collar
Yah- it's not installed yet- just test-firing it. I am thinking of painting it pink though.
Wed Oct 08, 2014 6:27 pm |
EFI Guy
Re: 351 collar
Bonus points if you can construct the hold down using nothing more than pink zip-ties.
Wed Oct 08, 2014 8:55 pm |
Re: 351 collar
Wed Oct 08, 2014 9:50 pm |
D&D72
Re: 351 collar
LMAO Eck. I may be able to scrounge some spacers that may work. Do you know what length is needed Garry?
Thu Oct 09, 2014 10:44 am |
Re: 351 collar
Any reason this wouldn't work?
Thu Oct 09, 2014 8:17 pm |
Moab Mike
Re: 351 collar
Thu Oct 09, 2014 8:59 pm |
EFI Guy
Re: 351 collar
Fri Oct 10, 2014 12:12 am |
Re: 351 collar
I cut an extra groove for the hold down. I will add a few set screws to lock the collar to the synchro. 20141215_163136.jpg
Tue Dec 16, 2014 2:31 am |
Re: 351 collar
Very nice.
Tue Dec 16, 2014 8:19 am |
Re: 351 collar
Any chance more of these will get made?
Tue Dec 16, 2014 10:20 am |
Re: 351 collar
Tue Dec 16, 2014 4:52 pm |
D&D72
Re: 351 collar
Yes I do have more in the works. I'll check with my buddy and get an update.
Tue Dec 16, 2014 6:28 pm |
Re: 351 collar
Here is my finished sensor. 20150117_162702.jpg 20150117_162639.jpg 20150120_191217.jpg
Tue Jan 20, 2015 11:52 pm |
Re: 351 collar
Well played.
Wed Jan 21, 2015 1:15 am |
JGZ
Re: 351 collar
Are these still available?
Sun Oct 11, 2015 7:06 pm |
Re: 351 collar
x2!
Sun Oct 11, 2015 7:22 pm |
D&D72
Re: 351 collar
I do have a few PM me a # and we can get arrangements made or meet up at ROX's in Nov.
Sun Oct 11, 2015 9:58 pm |
JGZ
Re: 351 collar
PM sent
Sun Oct 11, 2015 10:50 pm |
Moab Mike
Re: 351 collar
Any more of these available? Need one for my latest project.
Thu Jan 14, 2016 2:20 pm |
Re: 351 collar
Thu Jan 14, 2016 5:00 pm |
Moab Mike
Re: 351 collar
Thu Jan 14, 2016 7:16 pm |
Re: 351 collar
Fri Jan 15, 2016 4:36 pm |
Moab Mike
Re: 351 collar
Good deal, I'm in no hurry just wanted to make sure I wasn't out of luck.
Thanks again!
Fri Jan 15, 2016 5:31 pm |
Users browsing this forum: Google [Bot] and 23 guests |
