It is currently Thu Nov 21, 2024 11:01 am
LUBER build for my friend Todd
Re: LUBER build for my friend Todd
awesome to see some progress.
Sat Oct 19, 2013 6:25 pm |
Nice.
Are you doing the sheet metal work with your Hobart 210 welder? How does it do on the light gauge metal?
I'll be buying a 210 amp welder soon, and will sell my Lincoln 135 if I can do sheet metal work with the big one.
Sat Oct 19, 2013 7:20 pm |
Colorado75bronc
Ya I am, it works just fine when plugged into 110, it has more adjustability when plugged into 220. Id like to try it on thin metal on a low setting on 220, i just have to unplug the oven and run an extension cord through the garage entry into the house so i don't do it often, I would've posted earlier but didn't realize the tapatalk plugin was working again till today, and I've been pretty busy with work and other side work going for quite some time
Sat Oct 19, 2013 7:25 pm |
Yeah, great to see this moving forward. Looks like some nice work Corey!
Mon Oct 21, 2013 3:07 am |
Great progress and it looks like the panels are lined up nice. Is that a NP203 reduction case I see hiding in that pic?
Sat Oct 26, 2013 9:11 pm |
Colorado75bronc
Ya that's mine, not sure if I'm using it yet or not, thanks, the fender gap still needs some tweaking at the bottom, but I've already shown it to the body man and he said he can very easily work with it
Sun Oct 27, 2013 9:53 pm |
bump? any progress?
Wed Mar 26, 2014 7:39 am |
Colorado75bronc
Yeah it's still at the body shop, just just waiting, hopefully the body will be reunited with the chassis in a week or two, I've got to finish applying the POR 15 to the frame this weekend and it'll be ready, and hopefully the painter will be ready, after that it'll be in his hands fully for a while
Wed Mar 26, 2014 9:17 pm |
Crickets......
Thu Jul 24, 2014 9:24 am |
On the up side, you're making me feel better about how slowly my build is going...
Thu Jul 24, 2014 10:07 am |
Colorado75bronc
ImageUploadedByTapatalk1406219456.599446.jpgImageUploadedByTapatalk1406219468.700587.jpgImageUploadedByTapatalk1406219478.687635.jpgImageUploadedByTapatalk1406219489.241968.jpgImageUploadedByTapatalk1406219505.056669.jpgImageUploadedByTapatalk1406219516.577118.jpgImageUploadedByTapatalk1406219527.652943.jpgImageUploadedByTapatalk1406219550.764172.jpg
Thu Jul 24, 2014 10:32 am |
Colorado75bronc
ImageUploadedByTapatalk1406219580.605459.jpgImageUploadedByTapatalk1406219591.808420.jpgImageUploadedByTapatalk1406219643.592919.jpgImageUploadedByTapatalk1406219654.557372.jpgImageUploadedByTapatalk1406219665.898072.jpgImageUploadedByTapatalk1406219676.335019.jpg
Thu Jul 24, 2014 10:34 am |
Looks like some good progress.
Thu Jul 24, 2014 10:37 am |
Colorado75bronc
Sorry I've been busy and forgot to post, I'm currently dealing with engine/ trans to body issues due to the nv4500 swap, also had some issues with the painter, as soon as I get the body lined up to where the engine and trans are not contacting he will be coming over to touch up and respray some of the bedliner, for example the crooked line on the cowl and the spots he missed. And if he doesn't fix it to my liking the first try I'll be finding a new painter.
Thu Jul 24, 2014 10:38 am |
You know, it's more fun to fun at you when you're not making actual progress. Looking good!
Thu Jul 24, 2014 5:50 pm |
Looking good dude! nice your taking your time and giving the attention to detail.
Thu Jul 24, 2014 5:59 pm |
Colorado75bronc
Thanks guys! Ya I know Justin! And just know this I also parted out that 78' bronco and I went and pulled a 97' 351w roller for mine as I have decided to for-go the diesel swap and I'm tired of the 302 that burns 3qts every 1500-2000 miles. I know how you feel about not making progress though as Todd's has been in my garage for 2 years and I often neglect mine since it's my daily driver still and I get burnt out since I do it for a living as well
Thu Jul 24, 2014 8:04 pm |
Corey - you're doing a good job. That bronco looks amazing! Keep at it, finish 'er up and then take a little break before you tear into yours.
Fri Jul 25, 2014 12:50 am |
Colorado75bronc
Thanks JD, I'd love to take a break but being it's my daily it's going to be built/fixed at the same time as Todd's, plus I can't afford a second vehicle to be able to put mine down and I'm impatient and I haven't been wheeling in a year :P. Also I promised Crystal the next vehicle purchase will be for her and I'll take the lumina at that point as a beater/ daily driver
Fri Jul 25, 2014 9:50 pm |
