www.ColoradoClassicBroncos.com - View topic - 351 collar
It is currently Fri Nov 22, 2024 5:36 pm
Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3  Next
 351 collar
Post Re: 351 collar
Sun Jul 20, 2014 8:08 pm
Post Re: 351 collar
Sun Jul 20, 2014 8:45 pm
Post Re: 351 collar
Tue Jul 22, 2014 8:17 pm
Post Re: 351 collar
Has anyone else installed one of these yet? How did you put the retaining bolt in to keep the synchronizer put?
Also- with collar- only about 1/4inch of the oil pump shaft is engaged. EFIGuy gave me a part number for a longer shaft. I wasn't aware the shaft needed replacing so keep that in mind for anyone planning to do this in the future.
Wed Oct 08, 2014 5:25 pm
Post Re: 351 collar
That will need to be clocked correctly. The 5.0 is clocked parallel to the centerline of the engine. It also requires a special tool to hold the sensor in place when your installing it.
Wed Oct 08, 2014 5:44 pm
Post Re: 351 collar
That pink stuff wipes off (unless your trying to steal shawntell's motif)
Wed Oct 08, 2014 5:53 pm
Post Re: 351 collar
I've got ya covered on the tool to clock it correctly.
For the hold down ya gotta be creative. I've seen a longer bolt with washers welded together and ground for clearance, or two hold downs welded together like this:
Wed Oct 08, 2014 6:10 pm
Post Re: 351 collar
Yah- it's not installed yet- just test-firing it. I am thinking of painting it pink though.
Wed Oct 08, 2014 6:27 pm
Post Re: 351 collar
Bonus points if you can construct the hold down using nothing more than pink zip-ties.
Wed Oct 08, 2014 8:55 pm
Post Re: 351 collar
Wed Oct 08, 2014 9:50 pm
Post Re: 351 collar
LMAO Eck. I may be able to scrounge some spacers that may work. Do you know what length is needed Garry?
Thu Oct 09, 2014 10:44 am
Post Re: 351 collar
Any reason this wouldn't work?
Thu Oct 09, 2014 8:17 pm
Post Re: 351 collar
Thu Oct 09, 2014 8:59 pm
Post Re: 351 collar
Fri Oct 10, 2014 12:12 am
Post Re: 351 collar
I cut an extra groove for the hold down. I will add a few set screws to lock the collar to the synchro.
Tue Dec 16, 2014 2:31 am
Post Re: 351 collar
Very nice.
Tue Dec 16, 2014 8:19 am
Post Re: 351 collar
Any chance more of these will get made?
Tue Dec 16, 2014 10:20 am
Post Re: 351 collar
Tue Dec 16, 2014 4:52 pm
Post Re: 351 collar
Yes I do have more in the works. I'll check with my buddy and get an update.
Tue Dec 16, 2014 6:28 pm
Post Re: 351 collar
Here is my finished sensor.
Tue Jan 20, 2015 11:52 pm
Post Re: 351 collar
Well played.
Wed Jan 21, 2015 1:15 am
Post Re: 351 collar
Are these still available?
Sun Oct 11, 2015 7:06 pm
Post Re: 351 collar
x2!
Sun Oct 11, 2015 7:22 pm
Post Re: 351 collar
I do have a few PM me a # and we can get arrangements made or meet up at ROX's in Nov.
Sun Oct 11, 2015 9:58 pm
Post Re: 351 collar
PM sent
Sun Oct 11, 2015 10:50 pm
Post Re: 351 collar
Any more of these available? Need one for my latest project.
Thu Jan 14, 2016 2:20 pm
Post Re: 351 collar
Thu Jan 14, 2016 5:00 pm
Post Re: 351 collar
Thu Jan 14, 2016 7:16 pm
Post Re: 351 collar
Fri Jan 15, 2016 4:36 pm
Post Re: 351 collar
Good deal, I'm in no hurry just wanted to make sure I wasn't out of luck.
Thanks again!
Fri Jan 15, 2016 5:31 pm
Users browsing this forum: No registered users and 28 guests
32,954,511 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
