It is currently Sun Nov 24, 2024 10:49 am
[ 10 posts ] |
Black Friday Sales
Tom's Bronco Parts has their sale posted up: http://www.tomsbroncoparts.com/category ... -315705121RuffStuff Specialties-22.5% off anything they make until 12/1, excludes axle housings. This is their best sale of the year: Discount Code DEARWIFE Poly Performance-10% off anything until 12/1: Discount code CYBERDEAL2014 Barnes 4WD-15% off anything until 12/2: Discount code THANKS Wild Horses-http://www.wildhorses4x4.com/specials-BLK-FRI-14EB Jeff's Bronco Graveyard-10% off everything, no code needed.
Fri Nov 21, 2014 10:46 pm |
Unaweep
Re: Black Friday Sales
Thanks for the link. Could someone answer a question for me? On page 2 for some radiator hoses, the ad state for 289, 302 & 351w engines. Then later in the add says wont fit 5.0 conversion. I have a 351w, this kit fits right? Can some explain this please? Linky.. http://www.tomsbroncoparts.com/product/ ... bronco-newJ.E.
Sat Nov 22, 2014 8:25 pm |
As long as you are running a stock Bronco style water pump and radiator, you should be fine. Problems begin to emerge with different water pump styles or radiator inlet/outlet configurations.
Sat Nov 22, 2014 8:34 pm |
Unaweep
Thanks for the very quick reply. I guess it's stock...never really thought about it. Serpentine belt, mid 70's block.
I'll order it. The previous owner used 4-5 hoses to make the connections, scares the heck out of me just looking at it.
J.E.
Sat Nov 22, 2014 9:01 pm |
If you're uncertain, snap a pic and post it.
Sat Nov 22, 2014 9:11 pm |
Sat Nov 22, 2014 9:58 pm |
Unaweep
Ok thanks, I'm in Denver this week so it'll be a while.
J.E.
Sun Nov 23, 2014 12:31 am |
Updated the initial post with new discounts. The RuffStuff discount is especially good.
Mon Nov 24, 2014 11:31 am |
Updated with WH and JBG Black Friday specials.
Tue Nov 25, 2014 3:26 pm |
Wed Nov 26, 2014 11:48 pm |
[ 10 posts ] |
Users browsing this forum: No registered users and 51 guests |
