It is currently Mon Nov 25, 2024 8:36 am
[ 6 posts ] |
Measurement needed
Bottom of the frame rail to the bottom of the rocker. Outside width between frame rails.
Thanks.
Thu Jan 08, 2015 3:22 pm |
Woodscaper
Joined: Fri Nov 19, 2010 11:16 pm Posts: 587 Location: Lakewood/Green Mtn.
Re: Measurement needed
So, my rockers hang down 1" below the frame rail. I do have the rock skis however, so they add at least 1/4" as to the thickness of the ski. As for outside to outside of frame rails I am at 29 1/4" just behind T-case.
Sat Jan 10, 2015 2:19 am |
Thanks.
Sat Jan 10, 2015 2:28 am |
Most of the frame is 29.5". From about the engine mounts forward it necks down to 29.25". Why they didn't make it the same all the way I don't know. Measurements on my frame vary slightly from the picture, so beware of build variation.
Sat Jan 10, 2015 11:45 pm |
Sun Jan 11, 2015 1:39 am |
Can't take credit for that one, but I have been using it to make an awesome CAD model of the frame.
I dropped the complete picture in the technical links thread. It has more views and sections. Very accurate.
Sun Jan 11, 2015 10:45 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 61 guests |
