It is currently Mon Nov 25, 2024 8:35 am
[ 5 posts ] |
Diesel bypass filter feedback
Any diesel dudes running a aftermarket bypass filter? I'm thinking of adding one, the Amsoil setup looks easy to install and the price is right. I already have a spare pressure port to use and the 4bt pan has a second plug to use for return. I think the filter is a 1 or 2 micron spec, anything else I should consider?
Mon Jan 19, 2015 9:55 pm |
I'm running a secondary bypass oil setup on the Super Duty. And I love it. Haven't done a Blackstone report yet since I installed it. But the dudes over on FordTrucks say that they've pushed out to 10k between oil changes with no discernible difference in report readings over their previous 3-5k samples.
Mon Jan 19, 2015 10:00 pm |
Re: Diesel bypass filter feedback
Tue Jan 20, 2015 7:25 am |
I'm doing mine at 5k now. 10k sounds appealing but I just don't know if I trust second hand data just yet.
Tue Jan 20, 2015 12:07 pm |
I ran http://ecomicrofilters.com/ setup on my PSD. The only issue I had was getting replacement filters due to some sort of manufacturing issue, but I did find another source for those.
Wed Jan 21, 2015 9:09 am |
[ 5 posts ] |
Users browsing this forum: No registered users and 62 guests |
