www.ColoradoClassicBroncos.com - View topic - Garage Sale
It is currently Fri Nov 22, 2024 7:50 pm
Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Garage Sale
Post Garage Sale
*New Parts Added*
Here's what I got so far:
Master cylinder for an F250 Camper Special (I think it's a 1 1/4" bore) - new, just bench bled: $20
Set of 10 #19 Orange injectors from a 98 Exploder: $40
Fuel Rail, Fuel Pressure Regulator, and 8 #17 Beige injectors from a 99 Exploder: $40
Plastic Fan for Explorer serp setup (has some small cracking): $15
98 Explorer Valve Covers: $10 SOLD
Proform HEI distributor for SBF(cap, rotor, coil new last year) w/ set of new last spring MSD wires: $75
Duff Chrome transfer case shifter for T-shift w/ shifter boot, good shape: $50
Aftermarket coolant overflow tank: $5
OEM washer fluid reservoir w/ working motor, not cracked: $10
Windshield motor lowering bracket, $15
'98 Exploder 5.0L V8 upper plenum vanity plate: $20
Mechanical fuel pump for 302: $5
OEM 5 blade fan for 302: $10
10" Edelbrock air cleaner w/ K&N filter element: $15
'67 ash tray, red: $10
'71 windshield wiper motor & linkage: $30 SOLD
'67 stock style tailgate supports: $10 SOLD
Old Smittybuilt front bumper w/ ends trimmed off, good for a trail bumper: $25
4 spoke Grant GT steering wheel with adapter to mount to pre-'74 steering column: $25 SOLD
Smooth shift collar for truck switched to floor shift - blue: $40
'71 3 speed column shift tube (comes with shift collar, but collar may not be able to be used): $25
Parchment OEM visors, one small tear in one of them: $30 SOLD
R & L inner fender aprons newish: $50 for pair SOLD
Spark plug wire separators that clip on stock valve covers: $5 for pair SOLD
Edelbrock carb calibration kit #1479; I think it's pretty compete: $40
OEM alternator brackets for 302: $10
Throttle body for '98 Explorer $35
MAF for '98 Explorer: $30 SOLD
Passenger rear window track, new: $20
TBP bikini top with header, newish: $80
OEM Ford oil filler cap w/ PCV valve: $5
Stock rear tank w/ strap, sending unit, skid plate, and limiting brackets; tank doesn't leak, sending unit weeps a little: $40
Stock aux. tank with strap, sending unit, and limiting brackets; no leaks or dents: $50
*Some prices are probably negotiable.
Thu Feb 12, 2015 11:51 am
Post Re: Garage Sale
maybe on the valve covers. got a pic? seems to be quite the variety....
Thu Feb 12, 2015 3:22 pm
Fri Feb 13, 2015 8:43 am
I'm interested in the metal explorer fan and a fan clutch.
Do you take paypal?
Fri Feb 13, 2015 11:49 pm
interested in fan clutch and plastic fan, wondering if you still had them? THANKS
Sun Feb 15, 2015 8:22 pm
Mon Feb 16, 2015 8:17 am
Mon Feb 16, 2015 8:19 am
Mon Feb 16, 2015 9:12 am
Yah, those are the same as what I have from a 97.
Mon Feb 16, 2015 11:54 pm
Interested in the Accel pointless distributor w/coil for SBF.
Please send me a PM with contact information.
Thanks,
Jim
Tue Feb 17, 2015 8:56 pm
Can I get some details on the throttle cable, 2bbl, 4bbl, EFI, stock or stainless?
Size of the lights?
Also a pic of the coolant overflow bottle.
Wed Feb 18, 2015 12:25 pm
Wed Feb 18, 2015 1:58 pm
Wed Feb 18, 2015 1:59 pm
If Kirk doesn't take the throttle cable I'll take it.
Wed Feb 18, 2015 2:00 pm
Wed Feb 18, 2015 2:02 pm
Please set aside the throttle cable & lights for me, I'll pass on the bottle. Did you say you were or weren't going to make it to the build day? If not let me know a good way to grab parts & make payment.
Wed Feb 18, 2015 3:48 pm
Wed Feb 18, 2015 4:11 pm
A few parts added bump...
Wed Mar 11, 2015 8:07 am
Is the wiper linkage setup complete?
Wed Mar 11, 2015 8:15 am
Wed Mar 11, 2015 9:20 am
Post Garage Sale
Cool, I don't think the nuts & bolts are special, it's the clips & washers that are hard to find.
Wed Mar 11, 2015 5:31 pm
Kirk,
The only nuts/bolts/clips I could find were the two nuts and washers where the shafts come through the windshield. Let me know what you think.
Thu Mar 12, 2015 7:11 am
Parts added bump...
Tue Mar 17, 2015 7:45 am
I could use the steering wheel, got a pic?
Wed Mar 18, 2015 7:44 pm
Thu Mar 19, 2015 7:09 am
If you still have the wiper lmotor and linkage I want it.
Sun Mar 22, 2015 6:06 pm
Mon Mar 23, 2015 7:29 am
Items updated...
Tue Mar 31, 2015 7:25 am
Items updated. Make me an offer on any of the remaining parts if you're looking for something. I may post a few things on fleabay.
Sat Apr 04, 2015 8:36 am
Do you still have the fuel rail and #19 injectors?
Sat Jul 04, 2015 10:30 am
32,956,954 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
